Starter Replacement
1996 OLDSMOBILE CIERA
200,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
KENNY1970
How to change and where is it located?
Sep 10, 2016 at 8:55 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
You will need to disconnect the battery first before you begin. Next you will need to raise the car up safely.
Here is a guide
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is a guide to show you what you are in for when doing the job.
Here is what it will be like on your car (below) I got both engines just in case.
Cheers, Ken
Oct 18, 2017 at 2:49 PM
DARREL913L
Electrical problem
1995 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic 188.00 miles
Need to know the procedure for uninstalling old and installing new starter.
Thankyou
Oct 18, 2017 at 2:49 PM (Merged)
  • 110,190 POSTS
First, disconnect the battery. Next remove the wires from the starter. Finally remove the two mounting bolts holding it. Remove the starter, and reverse the sequence to replace.
KITO333
  • 6 POSTS
Electrical problem
1993 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic 94600 miles
i need to know how to take out the starter because my solenoid has failed tank you for any help sorry for not donating i would if i could very low on cash thanks again
Service and Repair
Upon removal of starter, note if any shims are used. If shims are used, they should be reinstalled in their original location during installation.
If starter is noisy during cranking, remove one .015 inch double shim or add one .015 inch single shim to the outer bolt. If starter makes a high pitched whine after firing, add .015 inch double shims until noise ceases.
1.Disconnect battery ground cable.
2.Raise and support vehicle.
3.Remove flywheel cover attaching bolts, then the cover.
4.Disconnect all electrical wires from starter.
5.Remove starter motor attaching bolts, then the motor by rotating the solenoid side toward the vehicle.
6.Reverse procedure to install. Torque starter attaching bolts to 32 ft. lbs. and inspection cover bolts to 89 inch lbs.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
CORSAIR15A
Engine Mechanical problem
1987 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic 110000 miles
I was just wondering how to go about replacing my starter in my 1987 Ciera.
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2745.jpg
