Mechanics
SECURITY LIGHT
2000 Oldsmobile Alero
Computer problem
2000 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
how to disable security system
1qazwsxedc
May 2, 2010.
You can bypass it by allowing the key to remain in the run position for aprox 10 minutes until the light turns off. Other than that, it needs to go to the dealer to identify where the problem is coming from. THey are the only place that has the proper equipment to identify the problem.
AD
