Mechanics
NO HEAT
2002 Nissan Sentra
Heater problem
2002 Nissan Sentra 4 cyl Front Wheel Drive Automatic 67000 miles
I GET NO HEAT. HAVE CHANGED THERMOSTAT AND CHECKED WATER PUMP
TIMSTOY
November 3, 2009.
Will let you know if I find a solution. Would you do the same?
Wdmurphy
Nov 7, 2009.
We found that there is a bleeder bolt around the thermostat housing. It is a a 10mm bolt that has blue paint on it. Bleeding the system solved the problem
AD
TIMSTOY
Nov 7, 2009.
AD
