Stalls while driving?
HEATHERTAYLOR10
  • 2004 NISSAN SENTRA
  • 1.8L
  • 4 CYL
  • 170,000 MILES
So my car has been shutting off while driving. It's just loses all power and I have to put in neutral to start it again. I took to Nissan today and had it put on the computer. The catalytic converter is going bad and it showed I need a negative cable to hook to my battery. Spark plugs and wires. Could any of those things cause my car to just shut off while driving.
Thanks,
Heather
Monday, February 16th, 2015 AT 3:48 PM
  • 108,310 POSTS
I would think if you are losing the ground to the battery, it would shut down the electrical / ignition system. I think this guide will help us fix it.
https://www.2carpros.com/articles/engine-stalls
Monday, February 16th, 2015 AT 6:57 PM
HEATHERTAYLOR10
My lights and everything stay Oh My God! Just engine shuts off.
Monday, February 16th, 2015 AT 7:00 PM
  • 108,310 POSTS
I would suggest waiting until the ground cable is replaced to see if that takes care of the problem. A disruption in electrical supply to the power control module can cause this to happen. If it still does it, then we will need to check to see if the fuel pump pressure is within the manufacturer's specs.
Monday, February 16th, 2015 AT 7:03 PM
HEATHERTAYLOR10
Thank you so much for your help!
Monday, February 16th, 2015 AT 7:39 PM
  • 108,310 POSTS
Glad to help. Let me know what you find.
Tuesday, February 17th, 2015 AT 5:43 PM
HEATHERTAYLOR10
Thanks for all the help! It was my cam sensor. That was part of the problem the battery was prob part also
Sunday, April 26th, 2015 AT 3:03 PM
  • 108,310 POSTS
Glad you got it fixed.
Tuesday, April 28th, 2015 AT 5:22 AM
JC314
  • 4 CYL
  • FWD
  • 98,400 MILES
Car over the last few weeks has developed a stalling problem. When slowing down to stop or taking off from a complete stop the car stalls out. You can typicaly put the car in N or P and it will start back up. Anyone have any suggestions in what might be causing this?
Thursday, January 7th, 2021 AT 12:55 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Maybe Throttle Control Actuator located on throttle body. Receives signal from ECM to keep idle in target range. Any check engine light?
JC314
Yes check egine right it has been on and off tho for last couple of years typicaly just adjust the gas cap it goes off.
DOCFIXIT
  • 18,828 POSTS
Go to an Auto Zone have codes read then post
ROBERT HANS
  • 1.8L
  • 4 CYL
  • 125,000 MILES
My daughter's car shuts off while she is driving. She has told me the car shuts off both at a stop and while driving, the e-brake light comes on and the it shuts down and comes to a stop. Today she was at a stoplight and check engine light came on, it started to move then all the dash lights came on brake, check engine, ABS etc. The tachometer went to red then o then back up to red then normal then the engine shut off. She was able to start it after a few minutes and she pulled in into a lot. When I got there and drove it, it responded fine. Start and stop fine, accelerated up to 100 fine, then I stopped and accelerated trying to trigger and all was fine. Ground wire on the battery looks corroded. Thoughts?
JIS001
  • 3,408 POSTS
Since the check engine light was triggered can you scan the codes and post them on here so we can have a starting point to assist. Here is a link on how to scan it:
EGREEN13
  • 2002 NISSAN SENTRA
I have a 2002 nissan sentra GXE with the small motor. It has 120K miles and it is a manual tranasmission. While driving the car will simply shut itself off. The symptoms of when it will happen are as follows:
1. When you ease off the gas the car feels as if brakes are applied.
2. The car bucks and the check engine light flickers, rpm gauge drops to zero and then comes back up. Almost as if the engine shuts off then bumps starts itself.
3. Engine shuts off and you have to turn the key back then restart which it does every time.
I recently had several sensors replaced due to a recall but the problem persists. Personally I think the computer is going bad because when the computer is checked the problems are not found. Thanks for your help!
AZUTNER
I have the same exact thing happen with my nissan the other day. This guide helped me fix it. It was a bad crankshaft sensor.
SENTRA5
  • 4 CYL
  • 129,000 MILES
Car starts and runs fine for several miles then dies at cruising speed with out stuttering or making any strange noises, Once you let it set 5 to 10 minutes you can then restart the car. Car does not do this every time you drive it. Thank You.
Thursday, January 7th, 2021 AT 12:56 PM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Hi, It sounds like your having a problem with the crank position sensor, but in order to be sure, the fuel and spark will need to be tested when this happens, I know it will be a little tough, to pull out tesing equipment while on the side of the highway, but we need to test these two things in order to find out what is wrong. I am thinking the crank sensor. Or a possible intermittent fault with the fuel pump. Fuel pump regulator, and fuel pump relay will cause the same symptoms.
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
BAW1079
  • 4 CYL
  • FWD
  • 147,000 MILES
My nissan sentra dies sometimes when it is put into gear. Other times it tries to stall while driving. It kind of drives jerky when it is trying to stall out. What could cause this and why?
Thursday, January 7th, 2021 AT 12:59 PM (Merged)
