Security reset?
ANONYMOUS
  • 2004 NISSAN MAXIMA
  • 135,000 MILES
I tripped the security on my car how do I reset it?
Tuesday, March 5th, 2013 AT 8:47 PM
  • 52,797 POSTS
Do you have a fob???
if not, try opening and closing the trunk lid also this guide can help
https://www.2carpros.com/articles/how-to-reset-a-security-system
Saturday, April 29th, 2017 AT 2:13 PM
JAY DANIELS
  • 2000 NISSAN MAXIMA
How to reset a factory alarm?
Friday, January 3rd, 2020 AT 4:01 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
To reset the security system remove the negative battery cable for 30 minutes, then reconnect the cable. Next, lock and unlock the doors using the remote. This will reset the alarm system and the engine will start this guide can help with instructions below.
Here are some factory notes.
Anti-Theft Systems
PROGRAMMING
NOTE: If a new Smart Entrance Control Module (SECU) is installed, a new identity code must be entered and all remote controllers must be programmed. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
PROGRAMMING > PROGRAMING NEW ID CODE
NOTE: This procedure will erase all previous identity codes and render all previously programmed remote controllers inoperative (until reprogrammed). All remote controllers to be used with system must be programmed at the same time. A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
1. Close and lock all doors. Erase original identity code(s) by inserting and completely removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position.
2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating identity code has been entered. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
3. For each additional remote controller to be programmed, manually release door lock and lock again by using door panel switch and repeat step 2. If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door.
(IF THIS DOESN'T WORK PLEASE TELL ME WHY IN THE VOTE TOOL)
MATT219
I have a 2004 Nissan Maxima. The car had 2 batteries tested for it and they were both both fine. I put the battery in the car and the security light blinks and beeps. That is all it does. When I turn the key there is nothing. Lights. Windows. Nothing works. Is there any way to reset the security without a key fob. I was never given one when I bought the vehicle
KEN L
  • 42,904 POSTS
Can you try locking the drivers door and letting the car sit for 30 minutes then unlock the drivers door. Watch when you crank the engine over to see if the security light is flashing. The fact that you have no electrical power for the windows seems strange. I would double check the battery cable connections and the fuses here is a guide to help you.
and
Check out the diagrams (Below)
Cheers, Ken
Friday, January 3rd, 2020 AT 4:02 PM (Merged)
SAMMY78SJ
  • 0 POST
  • 2003 NISSAN MAXIMA
  • V6
When I open any of my doors while im getting out of my car the alarm goes off. I lost my alarm remote and cannot now turn it off. Where is the switch in the car so that I can turn it off manually?
HMAC300
  • 48,601 POSTS
Thee I no switch you need another remote programmed t o your car to do it. Unless this is an aftermarket unit which you will have ot contact them.
LESTER 888
  • 2002 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • MANUAL
  • 68,000 MILES
Why 2002 maxima alarm goes off no reason
  • 108,192 POSTS
Chances are there is a sensor that is bad in the drivers door latch. I would replace it.
JW_NOWAK
  • 1997 NISSAN MAXIMA
  • 6 CYL
  • 180,000 MILES
I have a 1997 Nissan maxima, I started the car to let it warm up and then came back 10 minutes after and the car wasnt running. After getting it towed, I charged the battery and tried starting it. The inerior lights came on but the car wouldnt turn. After messing with the starter I got the car to crank a few times but the alarm goes off when the battery is connected and the alarm never worked? Theres power from the igniton to to the relay but the car wont start? I would love some qualified input
Friday, January 3rd, 2020 AT 4:03 PM (Merged)
JW_NOWAK
Nice this worked for my car but two months later it is not cranking at all and the alarm is going off when the battery is hooked up?
Get both the alternator and battery load tested if okay double check all connection start from here. If its an alarm/security issue why will it die out when it was running for 10mins. Normally is should prevent the engine from starting in the very beginning.
Here is a guide
No cranking could mean starter, starter relay, park and neutral switch, and igniton switch
GINNYAGNES
  • 1996 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 10,000 MILES
We bought a used Maxima and never got the key fobs. We never use the car alarm. Finally needed to replace the battery and now the car won't start because we can't reset the alarm code. How do I find my alarm code and how do I reprogram it to the car?
ZACKMAN
  • 4,202 POSTS
Is it factory or aftermarket alarm? If it is aftermarket, the installer usually leaves a reset button on the driver side kick panel. Just press the button and turn the key to ON position. That should reset the alarm.
If is factory alarm: Make sure all doors, hood and trunk are closed, and use the key to unlock the driver side door. That should reset the system.
JHALFORD
  • 1994 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 251,000 MILES
The anti-theft system seems to have a short. It has been a progressive problem. Now the keypad will no longer unlock the doors or fully disengage the anti-theft system. Consequently, though the car stars and the engine runs fine, the trans locks and the engine shuts down as soon as it is put in either reverese or drive.
I've already replaced all the anti-theft relays and fuses. But it seems the last resport is to disable the system.
How can that be done?
  • 31,938 POSTS
Hi there,
This system i believe can not be bypasses , that is what i have been advised anyway...
So i have added the full system check and test so you may be able to pin point your fault and get it up and going again.
Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_1_80.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_2_18.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_3_9.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_4_5.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_5_3.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_6_2.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_7_3.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_8_1.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_9_1.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_10_1.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_11_1.jpg
PURSUITPONY
Computer problem
1994 Nissan Maxima 6 cyl Front Wheel Drive Automatic
recieved the car two weeks ago. I drove it home and locked it in front of the house. Today I unlocked the drivers door, and when I opened it, the horn started blaring and the ignition was disabled(i know that's supposed to occur) my problem is that the former owner does not have the code to disable the alarm(she was the 2nd owner, and the original owner has since passed!) How do I disable or reset the system so I can start my car?
Thank you in advance
MANUEL11
Dear friend
you must have the remote contrl pad to disable the alarm. Check with the dealer to make one. To reset it is not that easy without the remote pad.
Let me know what are the results. Thanks and good luck
TASHIA81
  • 1993 NISSAN MAXIMA
Electrical problem
1993 Nissan Maxima 6 cyl Wheel Drive Type unknown Automatic 200000 miles
I have a 93 Nissan Maxima I am unsure if it's a SE or not it states that it is a Sedan on the title. I have an issue with my alarm system it goes off consistantly and is very annoying. I cannot disarm the system by simply putting in the key and turning it to left then right or anything else it says in the manual. I have tried various options I have read on other pages which includes cutting into a light green and black wire and then connecting it to the chassis with no results, besides the fact that now when I plug in my connector to the battery my front blinkers no longer work but the alarm system still activates. The blinkers also dont work after reconnecting the wires I have cut. That issue may be a fuse blown from attempting to disengage the system I am not sure. All I am wanting to do is disengage the alarm system and have my front blinkers working even if this causes my alarm system to never go off again. Actually that would be better. I am in need of getting it inspected.
MASTERTECHTIM
  • 4,749 POSTS
Have you tried unlocking the passengers door? It works the same as the drivers door. I will look at schematic and see if it can be disconnected. Hang tight
