Mechanics
POWER WINDOWS AND POWER DOOR LOCKS
1990 Nissan Maxima
Electrical problem
1990 Nissan Maxima 6 cyl Front Wheel Drive Automatic 140000 miles
Hi:
My power windows and power door locks stopped working today. They both work from buttons on the drivers door.
TOMMY802
January 2, 2008.
Do they work from the drivers door or not working at all? I dont understand. Check fuse -Z in the fuse block and test for power at the circuit breaker#1. Both systems run off the same power feeds
Jack42
Jan 3, 2008.
My power windows and power door locks don't work from anywhere. This is a 1990 maxima, I used to use the panel on the drivers door to lock the doors and close and open the windows.
AD
TOMMY802
Jan 3, 2008.
Get a test light and check the fuses and for power at circuit breaker #1
Jack42
Jan 3, 2008.
Are the fuses in the engine compartment? I don't see any fuses for the windows or locks under the left side dash.
TOMMY802
Jan 3, 2008.
Did you seea fuse labeled " Z"? Or a silver circuit breaker in the fuse block? If not look under hood next to battery
Jack42
Jan 4, 2008.
AD
