Heater not working
CRISTINESTEPHENSON
  • 2009 DODGE JOURNEY
  • 60,000 MILES
I've noticed that the heater doesn't work on the passenger front side of the car, how can that be fixed?
Friday, January 4th, 2013 AT 3:16 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,968 POSTS
Yes you have a blend door actuator that is probably out which is common on these cars. Here is a guide to show you what you are in for when doing the job.
This guide can help as well
https://www.2carpros.com/articles/car-heater-not-working
Here is what it will be like for your car diagrams (Below). Left, right, mode and recirculation.
Cheers, Ken
Wednesday, November 22nd, 2017 AT 5:46 PM
BUCKYPLUMBER
  • 3.5L
  • 6 CYL
  • 103,090 MILES
With the car at running temperature I have no heat. The car runs and drives just fine. It's warm air at slow speed and gets cold. All hoses feel warm. Dealership told me it was the water pump. I can't believe that to be true. Since the car operates just fine. And they want$990 to start
Wednesday, November 22nd, 2017 AT 5:47 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
Are the heater hoses so hot you can barely hold onto them?
This could be a heater door--actuator motor problem in the heater. As the heat is making it into the heater box
if they are barely warm---i'd investigate the thermostat 1st
i hate to throw this at you --- but I feel obligated, as this could be the condition. But maybe not (we hope). Failure to consider it, may cost you your engine.
. Do your other checks, if things are not working out.I'd stop driving it, till you get this checked
thing is----if the water pump is having an issue----not only are you cold in the cockpit----the engine coolant may not be circulating (or enough)
sometimes water pumps have plastic impellers---sometimes the same kinda pump from another parts may be offered with a metal one----sometimes the parts store may have both, with different warranty's or prices
personally, if available, i'd get pump with a metal impeller
i dug a little deeper for you---"advance auto parts" has "2"---only one of 'em allows me to look at the back side on their site.I screen shot it for you. See my 1st pic. This one is plastic!
I have taken several pics of pump failures with a plastic impeller. Keep in mind these are from different vehiclessee the rest of my pics. Especially the one that is just cracked (i wrote captions on it)
return with good news
the medic
  • 108,269 POSTS
If the car is not overheating and is running at a normal operating temp, I would assume the water pump and thermostat are fine. With the engine running, warm, and the heater on high, feel both heater core hoses. Both should be hot. If they are, then the blend air door is the problem. If only one is hot, then you have a plugged heater core.
Let me know what you find.
LIROL0469
  • 3.5L
  • 6 CYL
  • FWD
  • 102,500 MILES
2009 Dodge Journey SXT
It is blowing out air from all vents just not hot air
Temp. Gage starts out at cold and works its way up just below the medium line
Doesn't overheat, Runs fine, no noises when the air is blowing
When I put the car up to 3000 RPM's the heat started to blow warm (not hot even with blowers on full blast) but anything lower it would still blow cold air.
I also noticed that the passenger side did not get as warm as the driver side would when I had the RPM's high enough, but the 2nd and 3rd row was getting warm air also
I checked the coolant and the Coolant is filled
ARKERIC78
Let me tell you my experience.
I had a similar problem. My Dodge Journey would blow hot air on the driver side and lukewarm air on the passenger side. It then would have issues changing the air-flow from your feet, to your face, to the window, etc. After investigating the issue for about a month I have come to the realization that the computer in the Dodge Journey's is actually pretty clever if not SMART. You see, whenever there is a problem, anywhere in the vehicle with any component, the Dodge Journey will start giving you issues with things you will notice right away. When this happens, there is a fault/problem somewhere in your car. It doesn't mean that the problem your facing is the actual problem, it just means you have a problem and you need to look deeper as to the root cause. In my situation, it started to happen as the weather got cold. At first, I thought I had to replace the entire wiring harness as whenever I touched wires, the blending doors started to work. Which made no sense BTW. It drove me and the mechanic/repair shop crazy. We couldn't make any sense of it. A few weeks went by and we started to test the blending doors. We soon discovered that the blending acuator on the passenger side that regulates the heat/cold temperature was malfunctioning. Depending on how cold the weather got, the actuator would actually not turn. This would cause the computer to throw alerts and refuse to change the climate temperature on the passenger side. At the same time, it would not allow you to change the air flow from feet, face, to window and it would constantly default to the window air flow. The minute we replaced the blending door actuator, all the problems have gone away. I should also mention that when we hooked up a scanner to it, there were two faults that were totally unrelated to the blending door actuator which stated an open circuit. So, when your Dodge Journey is having problems and you can't explain them, look further. Take the time to investigate because the car is simply telling you that something is wrong. It is your job to diagnose the problem.
A few years ago, I had a fuse blow on me on the air bag system. I would constantly get an air bag light turn on in the vehicle. Took me a while to figure it out. The way the car was telling me that there is a problem is whenever I tried to put fuel in it, the pump would cut out. Once the fuse was replaced, I was able to pump gas no problems.
Wednesday, January 10th, 2018 AT 8:18 AM
KEN L
  • 42,968 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Wednesday, January 10th, 2018 AT 11:44 AM
2CP-ARCHIVES
  • 4,540 POSTS
  • 2010 DODGE JOURNEY
  • 62,000 MILES
My heater will not blow hot air what's the problem?
Saturday, February 23rd, 2019 AT 3:42 PM (Merged)
  • 52,797 POSTS
Low coolant level, bad thermostat, clogged heater core, blend door actuator or blown head gasket from overheating. Here is a guide to help us check a few easy things
SHARIQ
Thanks for the guide I had a coolant leak which let the coolant get low stopped the heater from working. I had to replace my radiator all fixed.
KAMISHA
  • 2.4L
  • 4 CYL
  • FWD
  • 98,000 MILES
My heater stop work. My blower motor been tested it works on tester but when u hook it back in vehicle it dont come on.
Wednesday, December 4th, 2019 AT 2:34 PM (Merged)
HMAC300
  • 48,601 POSTS
Have a pro scan this as it may be the blower motor module isn't working you might try pulling blower fuse with key on and maybe you'll get lucky and it will restart.
KAMISHA
Well I cant find a book to my 2010 dodge journey so dont know where to gind that module or fuse at Can u help me locate those things please.
KAMISHA
I meant to say I dont know where to find blower motor fuse!
HMAC300
  • 48,601 POSTS
The module a pro will have to scan for to see if it's bad or heater control is bad the module is at left rear of engine compartment check fuses m11, m34 and J19 on the module.
