fuel filter location?
1998 MERCURY TRACER
150,000 MILES
ANONYMOUS
Where is fuel filter located on my Mercury Tracer?
Mar 26, 2013 at 5:22 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
My info says it is located in rear of engine compartment, mounted in bracket clamp.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Mar 26, 2013 at 5:43 PM
JDL
  • 16,098 POSTS
Just wanted to add, don't take any fuel lines loose unless your sure there is no pressure on the fuel system.
Mar 26, 2013 at 5:45 PM
THYESDL
How do you change the fuel filter on this vehicle?
Sep 7, 2020 at 12:03 PM (Merged)
You probably need a special tool like below to remove it
https://images.2carpros.com/forum/automotive_pictures/12900_FUELFILTERREMOVERTOOL241103_2.jpg
MICHAELONLL
Engine Performance problem
1997 Mercury Tracer 4 cyl Front Wheel Drive Automatic
need to know how to replace fuel filter. the car has a misfire in #4 cylinder i have replace the coil pack plug wires and now im going to replace the fuel filter what else could it be if its not the fuel filter
BLUELIGHTNIN6
  • 16,542 POSTS
test the systems before replacing parts, will save a lot of money this way. test the fuel pressure. if OK check vacuum system for leaks. check PCV system for proper operation. many things to test for a misfire code so its very very difficult to guess at a part and replace it to fix the problem. and the fuel filter is not going to cause a misfire in only one cylinder
WILLIAM SMITH2
Can you please tell me where the fuel filter is?
WRENCHTECH
  • 20,761 POSTS
It is located in the engine compartment. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
