changing spark plugs
2002 MERCURY SABLE
RAGGAEMON
I have a 2002 Mercury Sable LS with 74,000 miles, I need to change my spark plugs but I'm not sure how to get to the plugs facing the passenger compartment.
Jun 19, 2007 at 9:41 PM
REYNOLDS810
  • 18 POSTS
A spark plug socket 3in ext. and a flex head ratchet for two of them stand on drivers side and reach between the master cyl and engine the last one do from passenger side they are not too bad to do but not easy.
Here is a guide that should help.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Jun 19, 2007 at 10:54 PM
RAGGAEMON
Thanks for the info, I can see how to change the plugs facing the front of the car but it's the one's facing the passenger compartment were tough but got it done. Thanks for the guide I love this site.
Jun 20, 2007 at 10:44 PM
DJC53187
I need to change my spark plugs+ignition wires and i am not sure how to do this? The 3 plugs and ignition wires on the backside of the motor are really hard to get to. Do you need to take part of the motor off or what? the reason i am changing them is because whenever i drive up a hill or try to increase my speed show and steady, the car starts hesitating and it feels like a plug is misfiring or it is not getting enough gas. then it goes away if i step on the excelerator pretty good.
Nov 26, 2018 at 12:19 PM (Merged)
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
yes you need to remove the upper plastic intake off
to gain access to the spark plugs
also check the coil too
GINO46
i want to know what i have to remove to change the rear 3 sparkplugs on a 24 valva dual overhead cam engine
FAIRRACING31
  • 150 POSTS
You can get to them by removing the coil pack, but unless you got the hands of a five year old it will be tuff. The fastest and easiest way is to remove the plentum. Consider replacing the plug wires at this time!
BIGBOY76
if the same sparkplugs that went bad before went bad again after being replaced what would cause that?
2CARPRO JACK
  • 11,533 POSTS
Possible. Need to re-scan it and pull the plugs and look.Most likely the rear were bad due to lazy, they are harder to change than the front.See if you get any new codes out of it
LUNDY76
My 2001 Mercurry Sable has been having a issue lately. I run the car for a little while then the car begins to shake and the check engine light flashes. I changed the spark plugs and spark plug wires and it helped for half of the day and it has started again. Anyone know what could be the cause of this issue
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
DHAYCOCK
I need to take my air intake manifold off and I took out 6 screws but there is something hanging up and it won't come off, I don't want to ruin anything. can you help me
CAMERONY670
My mercury sable is not starting. Engine turns over, but no spark. I have changed the ignition coil, ignition control module, distributor head, and most recently the pickup coil inside the distributor. I have had the starter checked and replaced spark plugs. But i believe the only issue is that no spark is leaving the ignition coil when I'm turning the key. I test 12v on the ignition coil tower when the car is on, so it is getting power. I am thinking it could be some bad wiring from the pickup coil to the ignition coil but I don't know where to start. Please help! Thanks.
  • 110,190 POSTS
Did you replace the crank sensor?
CDNDRY
sounds like it has a miss replaced spark plugs ran smooth then it started to miss again . itll run smooth at a light some times then other times it run rough and when i steep on the gas while driveing it will stumple but when driveing on the highway it runs fine as long as i dont step on it . could it be a bad wire and if so hould i check to see which wier it is thank you for any help you can be
Do you have a check engine light ?
Check the fuel pressure/idle air control valve/TPS/MAF/MAP sensors-
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
DOUG MORLAND
Just bought a 1998 Mercury Sable LS: v6 Durotec, 3.0l, 111km. I want to change the plugs (which I've already bought) and I see the front 3 plugs. Where are they hiding the rear 3 plugs and how on Earth do I get at them?
My first question here, thank you.
MERLIN2021
  • 17,250 POSTS
they are between the firwall and the opposite side from the front! reach around and use your plug socket!
DOUG MORLAND
Thanks, I figured that part out. I'm not sure if your intent was meant to be sarcastic or something?
I HAVE tried "reaching around", looking around, trying a mirror, even up from underneath and I did get a practical solution from someone who said to undo the R.Cowl Screen, R.Cowl and the ignition coil. I'm reluctant to try that as there seem to be a lot of connections that I'm afraid to disturb without me really knowing a lot about the whole thing. It's amazing how difficult it seems to be to make an attempt to do these repairs by yourself?
Any other ideas out there?
Thanks again...Doug M.
Nov 26, 2018 at 12:20 PM (Merged)
MERLIN2021
  • 17,250 POSTS
All I can tell you now is it IS possible! Follow the plug wires, that are tucked in a conduit that guides them around.Take the air plenum off for more access!
FAIRRACING31
  • 150 POSTS
[quote:6e226fe534="Doug Morland"]Thanks, I figured that part out. I'm not sure if your intent was meant to be sarcastic or something?
Thanks again...Doug M.[/quote:6e226fe534]
Doug, you can reach your plugs by removing the coil pack, but even then it's a very tight fit.I find it just as easy and quick to remove the plentum as Merlin says and gives you plenty of room. If you do remove the plentum, you might consider to replace your plug wires if they are original. It really sucks to do all that work and then a month later have a plug wire go bad.
DAVE1968
I would suggest replacing your plenum gasket also if you go that route. It's not very hard to do, just basic r&r.
DONNANNEMAN
How do I get to the spark plugs on firewall side of engine?
I haveread rthat I need to remove part of intake manifold, Fellow at parts store suggested I disconnect exhaust and one engine mount to tilt engine forward and access plugs that way.
I also need to replace O2 sensor on that bank.
MERLIN2021
  • 17,250 POSTS
I would leave the exhaust alone and get the gasket set for the tune up. You let a flex pipe this old hang and you WILL be replaceing it! If it makes you nervous to take an intake off give the job to someone else...cheaper in the long run.
KAREN71165
Engine Performance problem
2003 Mercury Sable 6 cyl Front Wheel Drive Automatic
How to change spark pugs that are under the manifold on a 2003 Mercury Sable
JGAROFALO
  • 489 POSTS
Remove the upper section of the manifold for access to the spark plugs.
EMERALDLADYHUSKY
i jusy recentaly bought a 1995 mercury sable an i did a transmission flush and an oil change plus an tune up and bought new plugs for the sparks plug and wires what could it be now.also the odometer works for a minute and the next it stops
BLACKOP555
  • 10,386 POSTS
what seems to be your problem/
was teh odometer messed up before you did the tranny change?
when you say odometer do you mean speedometer or tachometer, or infact the odometer, thing that shows your miles traveld.?
WILLIES54
How are the rear spark plugs/wires accessed?
Dec 5, 2018 at 10:08 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
On this car you must remove the engine torque mounts and roll the engine forward held by a block of wood. Here is a guide to walk you through the steps on replacing the plugs.
Cheers, Ken
Dec 5, 2018 at 10:09 AM (Merged)
WILLIES54
Sorry about the lack of info. 24 Valve DOHC 3.0 L engine. Looks like the intake will have to come off, but I wasn't sure if you accessed it through the interior or by removal of the intake system. The engine mount tip was great. I just put it in park and moved the car moved the engine right over, plenty of room.
BMRFIXIT
  • 19,053 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
