No start no spark - 2004 Mazda RX8
TOM970
  • 2004 MAZDA RX8
Started yesterday to day dead batt. Charged batt- no start sounds like no compression just roll's over and sounds different. Heard a electric motor or something running with key off and determined ing relay bad replaced same and now nothing running or turned on with key off still no start and no spark.
Appreciate any help, never delt with rotary engine.
Thank You for your time
TJ
Saturday, November 15th, 2008 AT 3:41 PM
MABELE87
  • 6 POSTS
Tom970.I have the exact same problem did you ever find out what was wrong with it I could really use the help
Wednesday, March 2nd, 2011 AT 3:23 AM
TOM970
I don't know how this happened my problem is different but I'll try to answer your Q. 1. Checking fuses and relays 2. check compression if it's OK and there is no spark, check crank sensor if OK, change ing module under the coil pack.
This guide can help
Wednesday, March 2nd, 2011 AT 2:48 PM
MABELE87
  • 6 POSTS
Tom.I got it all figured out I flooded it really bad. I replaced the plugs and had to turn it over with the fuel pump fuse removed for almost an hour in ten second intervals of course. Yes thats right about an hour and killed my battery in the process but in the end it started thanks for the suggestions tho
Friday, March 4th, 2011 AT 3:01 AM
MABELE87
  • 6 POSTS
Oh and im pretty sure that the rotery engines do not have a timing chain, they have no cam shafts
Friday, March 4th, 2011 AT 3:05 AM
TOM970
Mabele87 Sorry I have two Mazda's the Miata and the rx8 and when answering your question I was thinking or the Miata. But your right and I had the completely wrong engine. I did have the same flooding problem and when it happens you have to dry it out as you did or just hold partial throttle and crank for ever to clear it out and you might run the battery down in the process. If you hold full throttle it won't do any thing but add more fuel. I can't remember what else it sets in the computer but with full throttle it won't cleare the problem.
Friday, March 4th, 2011 AT 3:19 PM
LSCRYSTAL
  • 2004 MAZDA RX8
  • 4 CYL
  • MANUAL
  • 48,000 MILES
Hello, My son bought this car last year and in the last 2 weeks he has trouble starting this car. It sat almost all winter but we did finally get it started put a new battery in and now a week later it will turn over but will not fire. Any suggestions? Have seen there are recalls on this car, but not sure if that is related or how to go about that process. Any help is greatly appreciated. Thank you, Dave Kiefer
Monday, April 13th, 2020 AT 12:57 PM (Merged)
JAMES W.
  • 2,394 POSTS
I checked for recalls on your car. There are 4.
1- passenger side airbag.
2- exhaust heat insulator
3-engine cooling
4- Front control arm abd lower ball joints
I also checked for TSBs, and there are several. The one that caught my eye was on "no starts".
You may want to check with your closest dealer on these. Hope this helps.
PABLO JIMENEZ
  • 2004 MAZDA RX8
  • 1.3L
  • 4 CYL
  • RWD
  • MANUAL
  • 86,000 MILES
Pulled it into the shop to do a clutch change. Started it up one day after work and let it run for twenty minutes then I shut it down. I came back two days later to see that my father-in-law had put it up on blocks so that we could work underneath, I try to start it and it just made an electrical noise. Not the normal noise a car makes when it tries to start. I just figured maybe it was some sort of a sensor from being up on the blocks off the ground to prevent it from running. I got the clutch change and everything looks good, I put it all back together and tighten everything at the specified torque. Then I tried to start it again and it did the same thing. It will not make the noise that a car makes when it is trying to start but the belt turns, more like just the electrical is going. Everything in the engine was brand new before I parked it, coils, plugs, battery, wires. I thought it was the starter so I replace the starter and it does the same thing. Please help me. I cannot even find anyone online with the same problem. All the lights that usually come on, come on when trying to start. It just does not make the regular starting noise. It has spark.
HMAC300
  • 48,601 POSTS
Check battery for condition including load test most places do for free then try a security system reset. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
RENEE L
  • ADMIN
  • 1,257 POSTS
Hi PABLO JIMENEZ,
If you decide to check the condition of your battery yourself here is a link to helpful information from this site that features written instructions, pictures and a video explaining how to load test your battery yourself. If you need further assistance please come back to 2CarPros.com. We are always happy to help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
COBRAMAN_114
  • 2004 MAZDA RX8
  • 4 CYL
  • MANUAL
  • 25,708 MILES
Engine Mechanical problem
2004 Mazda RX8 4 cyl Two Wheel Drive Manual
25708
My Mazda RX8 will not start, it ran fine yesterday, but today it will not start. It turns over, but sounds different, like no compression or spark. I have heard of engine failures to this model year, but don't know the symptoms. Does anybody have any ideas?
KHLOW2008
  • 41,814 POSTS
Hi Cobraman_114,
Thank you for the donation.
A TSB was issued for non starting, lack of power and/or presence of trouble codes, ( P2107, P2108, P2402, P0420). For such cases, the PCM has to be reflashed and this can only be done at the dealer.
ENGINE NO START, LACK OF POWER, DTCS P2107, P2108, P2402 OR P0420 - POWERTRAIN CONTROL MODULE (PCM) REFLASH
TECHNICAL SERVICE BULLETIN
Reference Number(s): 01 - 008/05
Affected Model(s): Mazda Special Program (MSP04) - 2004 RX- 8
Superceded Bulletin(s): 01 - 022/04, Date of Issue: November 01, 2004
Related Ref Number(s): 01 - 008/05, 01 -022/04
ARTICLE BEGINNING
APPLICABLE MODEL(S)/VINS
NOTE: This bulletin supersedes the previous bulletin 01 -022/04, issued on 11/01/2004. The REPAIR PROCEDURE and CALIBRATION INFORMATION has been revised.
2004 RX- 8 vehicles built prior to March 12, 2004
VIN Range: JM1FE17**40100001 - 40135536 "Â
DESCRIPTION
Some vehicles may experience the following concerns:
"Â Engine fails to start (cranks but no start) at cold engine temperature. This is caused by
flooded spark plugs due to slightly rich air/fuel ratio for cold starting.
"Â Engine is hard to start after short distance drive without engine reaching normal operating temperature at cold ambient temperature. This is caused by lower engine compression due to seals icing by moisture inside engine.
"Â Engine has lack of acceleration power and / or knocking when driving at more than approx. 6000 RPM or at high altitudes. This is caused by poor combustion gas sealing due to the lack of amount of oil supplied from the metering oil pump.
"Â MIL illuminates with DTC P2107/2108 stored in memory. This is caused by sub CPU - main CPU communication error after jumpstarting the engine due to dead battery.
"Â MIL illuminates with DTC P2402 stored in memory. This is caused by improper threshold setting for DMTL motor electric current tolerance.
"Â MIL illuminates with DTC P0420 stored in memory. This is caused by improper threshold setting for rear O2 sensor output tolerance.
COBRAMAN_114
So I could not figure out the problem by myself. So I just took the RX-8 up to mazda and they said the the spark plugs were shot and it caused the car to flood. Also the air filter was to dirty, which it did not look that dirty to me. Also the last thing that the car did not have any of the recalls for the computer update. So after they did all that the car is running better then when I bought it. But I also I am still getting rid of it because it burns to much oil for my blood and just all the other corks with it.
Anyway so if you have a problem for your rx-8 starting then it could be possibly these problems.
KHLOW2008
  • 41,814 POSTS
Thank you for the input.
Guess I jumped the gun by going too far ahead when the basics were overlooked.
The engine for this vehicle works great but its lifespan is something Mazda is unable to provide longevity.
Thank you for using 2carpros
SHACKMASTER
  • 2004 MAZDA RX8
2004 Mazda RX8 4 cyl Two Wheel Drive Automatic
pulled the car out of the garage and it stalled
now it wont start
sound like the started is turning but not engaging
thx
Cranks but no start condition-do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
TCHANGALAN
  • 2004 MAZDA RX8
  • 1.3L
  • 6 CYL
  • MANUAL
  • 140,888 MILES
Hello everyone I have a problem on my as start RX8 2004 there are two injector is alimanter to leave the computer out of six, and no diagnostic trouble code appears to me 'I change the engine computer he like I know what to do here is the one that exists in the rx countries
KHLOW2008
  • 41,814 POSTS
I am sorry I do not understand your question. Can you please rephrase it?
TCHANGALAN
You have my English is worse because I am French !
My problem is that (my Mazda RX8 not Demare and I controlling ignition coil on everything is ok. And the injector there are only two working forward and four aft not working no. That's crrect?
KHLOW2008
  • 41,814 POSTS
Sorry for the delay and I hope I understand you correctly.
Only front 2 injectors would be working at idle. 2 rear would work only after 5000 rom and the other 2 after 6250 rpm.
