1994 Mazda Protege Repair Question
Asked on March 17, 2008
1994 Mazda Protege shift not working
Whils driving,noticed the stick was getting sloppy. When i went to shift,the stick was not doing anything. It was loose and not engaging. I could still drive in a gear,but, could not shift. The clutch still worked .Is it most likely a linkage issue?
Answer
Replied on March 17, 2008
Linkage, shifter or cable, hopefully not the trans. look under the hood while someone moves the shifter (can be done with car off) see if anything moves, if not work your way back to the shifter
