serpentine belt replacement please?
2001 LINCOLN CONTINENTAL
150,000 MILES • 4.9L • V8 • FWD • AUTOMATIC
JAYNEWILBOURN
I think the a/c compressor froze up. It made a bad noise started to smoke and burned the belt off. So while I was driving my battery light came on and I lost my power steering. So can I bypass a/c compressor? If not could you tell me what belt I need to buy and a diagram and or any tips would be welcomed & very appreciated. Thank you
Jan 22, 2015 at 4:04 PM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
I have an easier suggestion. If it's the compressor that locked up, just unplug the clutch coil or remove the relay from the under-hood fuse box. The compressor is supposed to run in the defrost setting, so unplugging the clutch will let the pulley spin freely without engaging the locked-up compressor.
If the clutch is locked up, it will just run the compressor all the time. It sounds like that is not the case here, but if it is, look at the belt routing diagram on the sticker under the hood. It is highly unlikely your car model was ever available without air conditioning, but if it was, that diagram will show both routings and whether an additional idler pulley was used in that application. If the car was available without AC, any auto parts store will have a listing for the correct belt, but you'll have to look at their diagram to see if you have to remove the compressor and / or add other pulleys.
Jan 22, 2015 at 5:13 PM
BLAJC2000
can not get belt around the tensioner pulley? Can you help me?
Apr 8, 2020 at 5:59 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Assuming you have the correct length belt then put the belt on all the pulleys except the water pump. With the tensioner in the loose belt position then slide the belt over the water pulley. This way you don't have to clear the flanges on the alternator pulley
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_707.jpg
WALTER174
This guide helped me step by step
https://www.2carpros.com/articles/replace-serpentine-belt
MIKE55555
I need to know the proper routing for the belt replacement,and how to do it.Thanks
WRENCHTECH
  • 20,761 POSTS
https://www.2carpros.com/images/external/42184580.jpg.gif
MIKE55555
Thankyou! So much
  • 54,336 POSTS
You are welcome please use 2Carpros.com in the future and tell a friend :-)
HOMESKILLET
I just changed the alternator in a 1991 Lincoln Continental, and when I put the belt back onto the alternator, it was loose. I checked it for damage, and it is fine. It appears that the tensioner pulley is also fine, and i haven't missed any pulleys as far as I can see. What could be the problem?
MIKEYBDMAN
  • 623 POSTS
[quote:955c3286b3="Homeskillet"]I just changed the alternator in a 1991 Lincoln Continental, and when I put the belt back onto the alternator, it was loose. I checked it for damage, and it is fine. It appears that the tensioner pulley is also fine, and i haven't missed any pulleys as far as I can see. What could be the problem?[/quote:955c3286b3]
The routing of the belt can be tricky some times. Usually there is a diagram with the routing. It can be as simple as what point you go around the tensioner. Check your routing versus the diagram and see if it is correct.
If it is, then suspect the tensioner has gone bad. My money is on the routing.
