1993 Lexus LS 400 no power
MARK FRIZZELL
  • 1993 LEXUS LS 400
  • V8
  • 217,000 MILES
Motor is a 1uz-fe v8 overhead cam 32 lexus. Car has been maintained properly throught the years was running Great! All of a sudden on the way home from work it loses half it's power. It accelerates fine in park but notice some things engine sounds muffeled. And a bad smell. And rattle on the right side of engine compartment. Sound maybe coming from underneath the car. It doesn't really act like a normal misfire or plug. Acts like it's running on half the cylinders. Can the cat conver cause this kind of loss? I was able to reaCH Hwy speed but sluggishly.
Saturday, July 19th, 2008 AT 12:34 PM
KHLOW2008
  • 41,814 POSTS
Hi Mark,
Thanks for the donation.
Yes, if the cat converter is clogged, it would cause insufficient exhaust flow. When no load revving, you would not notice much difference. Going at higher rpm on load, the back pressure would cause insufficient airflow into the cylinders from the intake resulting in very bad performance.
The bad smell and muffled sound is similar with a failed cat converter.
Sunday, July 20th, 2008 AT 12:38 AM
MARK FRIZZELL
  • 141 POSTS
Thanks for the answer!
Also is it possible that if this the case it could have damaged th the 02 sensor and anything else associated with the exhaust monitoring system? And I can't find a repair manual for this lexus thats not the $200.00 OEM. Know of any others?
Thanks,
Mark
Sunday, July 20th, 2008 AT 2:02 AM
KHLOW2008
  • 41,814 POSTS
Hi Mark,
Before the catalytic converter fails, it might have operated at a very high temp, even glows red so it could cause the O2 sensor to fail. Any misfiring of engine cylinders could be the initial cause.
Sorry I have no idea of after market parts, maybe you can try Autozone and see if they have any.
Sunday, July 20th, 2008 AT 6:46 AM
MARK FRIZZELL
  • 141 POSTS
Yes the converter was clogged, so bad it blew a chunk of it out and logged itself against the senser.
I know it is unlawful to remove the converter due to emission laws, but my question is if there was no converter would the engine run incorrectly, or would the sensors readjust for the change? Hypothedicaly.
There is a sensor before the cat. And one after, 02 and? What is the other. Pressure?
This concludes my questions u have been a great help, WORTH EVERY PENNY!
Thanks Mark
Sunday, July 20th, 2008 AT 10:55 AM
KHLOW2008
  • 41,814 POSTS
Hi Mark,
You are welcomed.
Without the cat converter, the car would still run well but the check engine lights would show sooner or later. You would also fail emission.
Both are known as HO2S (Heated Oxygen Sensor), only difference is front and rear. The front sensor is to monitor the exhaust gas and and inform the ECM to make the necessary adjustments and the rear is to monitor the catalytic converter efficiency.
You are welcomed to drop by any time you have a question.
Have a nice day.
Sunday, July 20th, 2008 AT 2:20 PM
MARK FRIZZELL
  • 141 POSTS
Need more help here. I have repaired the converter, replaced the h20 senser, car does seem to be missing. My mistake. Is it possible something happened and this caused the cat to fail, which in turn damaged the sensor? Car runs real rough(bad) smell raw gas out of exhaust, ECM maybe failed? If so where is it located? Please read back through the thread maybe u can give me a few things I should look for other than the obvious, it seems to be missing on the right bank of the engine, at start up if u rev it alittle it pops back ( just once ) as it warms up it quits. But still seems to be missing.
Thanks, Mark.
Monday, July 21st, 2008 AT 5:58 AM
KHLOW2008
  • 41,814 POSTS
Hi Mark,
If any of the cylinders is misfiring badly, it could cause the catalytic converter to glow red hot when rich fuel is pushed through it for a period of time. That could be the initial cause of the catalytic converter failing.
Should be an electrical fault as fuel is present.
Check the spark plugs and related parts. Compare the 3 plugs of one bank and see if the color of the plugs tips and ceramics are similar, the one that looks sooted should be the main culprit. Compare them with the other bank of 3 plugs to get an idea what it should look like.
If all looks sooted, you need to replace them.
Monday, July 21st, 2008 AT 6:32 AM
MARK FRIZZELL
  • 141 POSTS
So, ur saying that It could be just a fouled plug?Or two becuase it seems directed to only one side?
Not the ecm?
Monday, July 21st, 2008 AT 7:38 AM
KHLOW2008
  • 41,814 POSTS
Hi Mark,
Yes, that is possible.
The ECM is a reliable component the chances of it failing are minimal.
Btw is the CEL still showing? If yes, what is the error code?
The other possible reasons are bad injectors, allowing more than designated amount of fuel to go through.
Bad igniton coil or wires could also cause it. Check for oil or water in plug holes.
Monday, July 21st, 2008 AT 2:56 PM
MARK FRIZZELL
  • 141 POSTS
Well after digging a little deeper. I found that the left bank distributor was not firing and the car is running on the right bank Dist only! (4 cyl's!).
Now I have determined that there is no fire from the left bank coil! Other than 12 volts is present. My question is. Is there anything other than just a bad coil at this point is there anything that would not allow the coil not work? There is 12 volts passing thru it, but no high voltage coming from it.
Wednesday, July 23rd, 2008 AT 10:27 AM
KHLOW2008
  • 41,814 POSTS
Hi Mark,
Sorry for the late reply.
Other than a bad coil, you need to check if it is a camshaft sensor fault which should show on a scan.
Test the coil resistance (ohms)
Cold
Primary resistance = 0.36 - 0.55
Secondary = 9,000 - 15,400
Hot
Primary resistance = 0.45 - 0.65
Secondary = 11,400 - 18,100
Camshaft sensor resistance
Cold = 835 - 1,400
Hot = 1,060 - 1,645
Wednesday, July 30th, 2008 AT 4:22 AM
MARK FRIZZELL
  • 141 POSTS
It was just a bad coil on the right bank, thank u for all ur help!
Monday, July 18th, 2011 AT 9:30 AM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Glad to know the problem is fixed.
Have a nice day.
Monday, July 18th, 2011 AT 1:00 PM
