Charging the air conditioner
CONFUSED252
  • 2007 KIA SEDONA
  • 6 CYL
  • FWD
What kind of Freon do I use to charge the air conditioner? I do not have the owners manual.
Friday, April 29th, 2011 AT 10:41 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,973 POSTS
You will use 134a and it is relativity simple to do here is a guide that will help you get the job done.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Best, Ken
Tuesday, April 18th, 2017 AT 4:05 PM
DON ALD
  • 2006 KIA SEDONA
  • 6 CYL
  • 68,000 MILES
Air Conditioning problem
2006 Kia Sedona 6 cyl Two Wheel Drive Automatic 68000 miles
We have had this vehicle since new and not nad this problem before now. In May, we had the 65K service (replaced timing belt.) In June after the outside temps got hot, the A/C compresssor had a complete failure which sent debris throughout the system. 1600$ later at dealer, we have a new AC and flushed lines.
After several weeks to a month, the A/C failed again and they replaced the copmpressor. A few weeks later, it failed again and they replaced the entire system and cabin switches. Last weekend, It started to act up and smoke, I immediately turned the car off and restarted the vehicle with the hood up to watch for trouble. The A/C ran fine all the way home and appears to be fine now.
At each failure, it was durring the heat of the day (above 105 degrees F outside). The car had been sitting outside for at least a few hours when at startup the AC failed/ or acted up.
My initial questions are: Are there any ancillary connections to the A/C system that could be causing this repeated failure? Is it possible that the 65K service is related to this failure (overtight belt.)?
I appreciate any input or advice regarding this question as I am concerned that if we don't get it resolved before the temps drop, I will be out of warranty when it failes next.
Thanks,
Don
Tuesday, April 18th, 2017 AT 4:06 PM (Merged)
BILLYMAC
  • 2,204 POSTS
This is tough. Compressors rarely fail this often if you have to replace one in the life of the vehicle that is usually the only time you would have to do that.
You said they replaced the whole system does this mean the evaporator under the dash.
The condensor behind the radiator the rubber hoses under the hood reciever drier orphice tube all of these parts can hold contamination such as debri from a failed compressor.
It sounds to me like possibly the control switch is sending power through a ground I would go back and let them have another look and atleast this prob will be documented and in the future it will help
ANGFET24
  • 2005 KIA SEDONA
Where do I charge my freon on my 2005 Kia Sedona? I am not seeing the valve shown on the instructions when looking under the hood. Thanks.
  • 31,937 POSTS
It looks as if one is in front off the radiator near the air intake duct and the other near the receiver dryer, check out the image below
SNOSAINT
  • 76 POSTS
  • 2005 KIA SEDONA
  • 6 CYL
  • FWD
  • 56,000 MILES
I would like to know what the low pressure side readings/specs should be when the A/C is on and when it is off. Cooling seem a bit weak & the compressor is cycling on/off more than I think it should. I have one of those consumer type trigger guages that show it in the "blue" (full charge) about 40PSi on & 105psi off. Did not check high sige as I dont think this guage is meant for that. I also note ther is a distinct hum when the A/c is turned on. If its low I plan on adding some of the synth stuff that has some oil & super cooler in it.
Saturday, September 7th, 2019 AT 12:39 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
If the cooling cycle is operating normally, the gauge reading will be about 1.5 - 2.0 kg/cm squared (21 - 28 psi) for the low pressure side and about 14.5 - 15 kg/cm squared (206-213 psi) for the high pressure side. Inlet temperature should be 80 - 95F, with the engine at 2,000 RPM, maximum cooling selected, and the blower on highest level.
Here is a guide to help with a video.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
https://youtu.be/uZrQCGwXfek
