2CarPros - Car Questions & Answers
2006 Kia Optima Repair Question
Topics covered: Electrical connector, Engine, Fuel pump.
Asked on July 12, 2008
2006 Kia Optima Fuel Pump Removal
I am trying to replace the fuel pump. I have access to the top of the fuel tank and have removed the electrical connector and the two hoses, however I cannot figure how to remove the locking ring? It is completly smooth and only has eight holes around the top of the ring, can nayone help on this??
Avatar Asked by siouxwarrior67
Answer
Replied on July 12, 2008
You'll need the spanner wrench, or a brass punch and hammer to tap it off without destroying it...
Tiny Answered by merlin2021 (expert)
18,145 answers provided
I was able to get the ring off, and I replaced the pump, but the car still will not start, any ideas?
Tiny Response from siouxwarrior67
1 question asked
What tests have you run? First thing is fuses and relays, under the hood and in the car, also retrieve any codes stored in the PCM. Then test for power at the connector to the pump.
