2000 Infiniti I30 Repair Question
Asked on November 25, 2008
2000 Infiniti I30
Engine Mechanical problem
2000 Infiniti I30 6 cyl Front Wheel Drive Automatic 100000 miles
my 2000 infiniti I30 will turn over, make a "revving noise" but won't start- we just replaced the battery about 2 weeks ago, because it would turn over but wouldn't start! could it be the starter?
Answer
Replied on November 26, 2008
If it is cranking (as if it wants to start) but doesn't turn over, your starter is working. You need to check for fuel pressure on the fuel rail and also power at the fuel pump connector. If there is no pressure and you have power, chance is your fuel pump is bad.
