2000 Hyundai Sonata Repair Question
Topics covered: Fuel filter, Engine, Fuel pump.
Asked on February 23, 2010
Fuel filter
Engine Performance problem
2000 Hyundai Sonata 6 cyl Front Wheel Drive Automatic 110000 miles
Where is the fuel filter located and how is it changed?
Answer
Replied on February 23, 2010
Under the vehicle at the left front corner of the fuel tank.
FUEL FILTER REPLACEMENT
1.Reduce the internal pressure of the fuel lines and hoses and perform the following operations.
*Disconnect the fuel pump harness connector in the trunk room.
*Start the engine and, after it stops, turn the ignition switch to OFF .
*Disconnect the battery negative (-) terminal.
*Connect the fuel pump harness connector.
2.Remove the two fitting nuts while holding the fuel filter nuts securely.
3.Remove the fuel filter mounting bolts, and then remove the fuel filter from the fuel filter clamp. Tightening torque Fuel filter fining nut 25 - 35 Nm (250 - 350 kg.cm, 18 - 25 lb.ft)
