Blower motor not working
DEBBIES59
Thank u very much. U have been very helpful. Debbie
Saturday, January 26th, 2019 AT 4:18 PM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Oh, you are quite welcome, anytime.
RTHENDERSON
  • 2005 HYUNDAI SANTA FE
  • 6 CYL
  • 147,000 MILES
Heater blower/switch does not work. Checked fuses. Fuse for blower would not register on fuse tester. Tried 3 new fuses, but none would trip fuse tester. Is it the blower or the switch?
SERVICE WRITER
  • 9,123 POSTS
Check the switch, pull it out and look for burnt areas. You can also put power to the motor to verify it works.
CHOOCHABOB
  • 2004 HYUNDAI SANTA FE
  • 6 CYL
  • FWD
  • 69,700 MILES
The #2 position fan speed has been out for awhile. Now, the #1 and # 3 speed positions are out leaving me with the High speed only. What's my course of action. Simple, I hope.
KHLOW2008
  • 41,815 POSTS
Hi choochabob,
Most probably the blower speed mode resistor unit is faulty and needs to be replaced.
TOM HOB
  • 6 CYL
  • 92,000 MILES
The blower ouit working I checked the fuses under the dash also under the hood could you tell me where the blower is located and if you have any advice for me.
  • 108,262 POSTS
The motor is under the dash on the passanger side. Check to see if it is getting power. If it is, then the motor is most likely bad.
Let me know what you find.
KADI
  • 5 POSTS
  • 90,000 MILES
When I turn the on/off **** I can hear the motor click. But it doesn't come on. What do I need to check and were do I find everything?
Check the blower motor-power it from the battery and see if it comes on-if okay-check the blower motor resistor/fan control motor and relay-
  • 108,262 POSTS
Check for power to the blower motor. If there is power, the motor is bad.
KADI
  • 5 POSTS
Ok I figured out it is the actual switch in the control panel. It doesn't work at any speed, but if you push up or down on the ****, the blower turns on and works fine. I've read that I can pull the panel and replace the switch. But it also says to be sure to unplug the batery to disarm the airbags. Are there any other precausions I need to know about?
  • 108,262 POSTS
Allow the battery to be disconnected for at least 20 minutes before working on or around the air bags.
2CP-ARCHIVES
  • 4,542 POSTS
  • 2001 HYUNDAI SANTA FE
  • 160,000 MILES
Heater blower motor does not blow or blows intermittently
  • 52,797 POSTS
Check for power to the motor with a voltmeter to confirm the motor failure.
Otherwise the resistor may be the issue
