i need to know where the starter is located on my 2001 hyundai santa fe and how to replace it
Jan 28, 2011 at 4:39 AM
CAR REPAIR CONTRIBUTOR
Disconnect the battery ground cable.
Remove the speedometer cable and the shift cable.
Disconnect the starter motor connector and terminal.
Remove the starter motor assembly.
Installation is the reverse of removal.
Images (Click to enlarge)
Jan 28, 2011 at 5:16 AM
Here is a guide that will give you an idea of what the job with take.
Cheers, Ken
Image (Click to enlarge)
Oct 17, 2017 at 8:02 PM
FELIXFINE
MEMBER
1 POST
Engine Mechanical problem
2001 Hyundai Santa Fe 6 cyl Front Wheel Drive Automatic 340582 miles
where is the starter located? I can't find it & do not have a repair book to look up the location. Thanks
Oct 18, 2017 at 10:39 AM
(Merged)
KHLOW2008
Hi felixfine,
Look under the intake manifold at trans mission side.
Simple procedure is to follow the battery positive terminal cable to where it ends.
(Merged)
