Fuel filter location
SJLJ
  • 2003 HONDA ELEMENT
  • 4 CYL
  • 4WD
  • 110,000 MILES
Where is the fuel filter located? The car will go 40 mph but if you press on the gas to go faster it slows down. Will maintain the 40 mph fairly well.
Sunday, December 19th, 2010 AT 6:51 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,973 POSTS
The fuel filter is in the fuel tank attached to the fuel pump. It sounds like the pump is going bad or you have a plugged catalytic converter.
Here are some guides and diagrams (Below) to help you get the problem fixed.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and
https://www.2carpros.com/articles/engine-has-low-power-output
To drain the fuel before you begin to change the fuel filter.
https://youtu.be/Q5MH2gnyFH0
Cheers, Ken
Saturday, July 29th, 2017 AT 6:38 PM
ELEMENT08_GUY
  • 2008 HONDA ELEMENT
  • 2.4L
  • 4 CYL
  • AWD
  • 126,500 MILES
How do you replace the fuel filter in a 2008 Honda Element
Saturday, July 29th, 2017 AT 6:39 PM (Merged)
HMAC300
  • 48,601 POSTS
Fuel filter is in the tank no need to replace until pump is.
