Seat Does Not Move?
MAHMOOD1
  • 2003 HONDA ODYSSEY
  • 6 CYL
  • 4WD
  • 198,521 MILES
Driver seat does not move forward and back, also does not move up and down at front end. I checked motor one by one by give direct twelve volts all three working good. I check trackaldo. I got second button switching assembly but have same response. Headrest means back of seat is working and up and down is working at rear end. But does not work on front end up and down and does not work forward and back. Waiting for your response. Thanks
Sunday, November 12th, 2017 AT 12:11 PM
  • 31,937 POSTS
Strip motors from seat and check slide mechanism and tilt lever, if the motors work it will be a mechanical problem with the seat.
Sunday, November 12th, 2017 AT 10:24 PM
MAHMOOD1
I give power direct to motor after installation of seat. It moves forward and back good.
Sunday, November 12th, 2017 AT 10:26 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,072 POSTS
It sounds like a switch or a fuse problem. Here is a guide to show you how the power and wiring goes along with a copy guides to show you what to do.
and
Check to see where you loose power.
Cheers, Ken
Wednesday, November 15th, 2017 AT 6:11 PM
PAPA818
  • 2002 HONDA ODYSSEY
  • 87,000 MILES
Driver's seat won't go forward or back. All other seat controls work correctly. How to diagnos or check this out before going to a "real mechanic"?
Saturday, August 29th, 2020 AT 1:10 PM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
Test the switch terminals for the forward and backward movement. Use a multi-meter to check for 12 volts at the terminals. If it has 12 volts, the switch is bad and needs to be replaced.
PDHJSH
2002 Honda Odyssey 6 cyl 50,200 miles
My car was recently fixed at theHonda dealership for a faulty 15-3 OPDS sensor. It was fixed under warranty. Immediately after the work was done my driver's seat, at the base, lifts up when you lean back.
A plastic part broke off underneath the seat this may also affect the motor of the seat. How do I find out if this is covered under warranty or if the previous work damaged the driver's seat.
Thank you for any information you can give me.
KHLOW2008
  • 41,814 POSTS
Hi pdhjsh,
It is not easy to verify if the fault is caused by the repair job but since repair was carried out on the seat, you should get back to the dealer and get them to rectify the problem at no additional costs.
RONNELLIS
  • 2001 HONDA ODYSSEY
  • 6 CYL
  • AWD
  • 63,000 MILES
The strap used for lifting the 3rd row seats into place is stuck in the well of the back cargo area. How can I release the folded down seats to lift them in place without the strap?
2CARPRO JACK
  • 11,533 POSTS
Can you see the straps? You may need to fish them out with a coat hanger or the such.
RONNELLIS
Hi Jack -
Before I got your response, a friend managed to stick his hand into the back corner (closest to the bumper) of the seat well and get his hand down to the second level of the folded seat. By grabbing the corner, he was able to lift the entire bifold seat assembly and reveal the buried strap. I can't get my hand into the space he got his into to lift the seat, so I guess you need a thin-handed person with a good bit of strength to pull this off.
Your idea to fish out the stap may well have worked. For sure the secret is to get leverage from the second level of the seat assembly in order to lift it.
DRD1821
  • 6 CYL
  • AWD
  • 194,000 MILES
The plastic lever that disengages the third seat for folding down for cargo, seems loose and does not work. I suspect that the cable is either disengaged or broken. I can't see how to even get at it for repair.
Help!
HONDA TECH 1818
  • 536 POSTS
The latch cable is disconnected from the handle.
There is two screws holding the handle, remove the screws and handle to reconnected the cable.
BELLABUGGY
  • 2000 HONDA ODYSSEY
  • 6 CYL
  • FWD
  • 110,000 MILES
When I pull the release lever for the 3rd row, it will no longer fold flat into the floor. (The seat back still folds down, but the bottom will not flip over into the floor)
It feels like there is no resistance - maybe a cable is broken/unattached? This happened suddenly and with no indication anything unusual had occurred.
Will this be expensive to fix? Rough guesstimate on cost? Does ithave to go to a Honda dealer or could another mechanic do it? Is this a difficult repair - anything I could do myself?
Thank you so much!
KHLOW2008
  • 41,814 POSTS
Hi bellabuggy,
Most probably the latch is stuck and not releasing from the strikers.
Remove the recliner Lever trim to see if any cable is detached.
https://www.2carpros.com/forum/automotive_pictures/192750_Odyssey2000reclinerTrim_1.jpg
MEHROLI
  • 1996 HONDA ODYSSEY
  • 2.2L
  • 4WD
  • 210,000 MILES
I'm planning to build a camper bed into my Odyssey and I cant figure out how to remove the seats in the second row. Would be so nice if someone could send me the link to a Video Or a guide with fotos Or even only a written guide which is easy to understand. Thanks
Levin
Saturday, August 29th, 2020 AT 1:11 PM (Merged)
RIVERMIKERAT
  • 6,110 POSTS
Here's what I found.
http://www.odysseyownersclub.com/forums/showthread.php?t=613
http://www.odyclub.com/forums/28-1995-1998-odyssey/67428-how-remove-rear-fold-down-seat.html
