windows stopped working?
2012 HONDA CIVIC
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
ED AUCOIN
Battery went bad too. put a new battery in car starts fine everything works but the windows.
Nov 7, 2019 at 6:28 PM
  • CAR REPAIR CONTRIBUTOR
Have you checked the power window relay? It is L6 relay on the under dash relay box. Swap out this relay and let me know if they start working. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Thanks
Nov 8, 2019 at 3:19 PM
DEUTSCHG
My 2004 Honda Civic SI- the power window on driver side only is having a problem. It goes down fine and then when I pull the electric switch to make it go up, it goes up a little and then back down imediately. This happens over and over. I turned it off and on and kept doing it and eventually it went all the way up. This has happened twice. The manual says it has an automatic thing that makes it not close on things in the window, and it kind of acts like that, but there is nothing in the window to cause it to go back down. I think it just needs an electrical type reset. Is there anything I can do?
Jan 4, 2021 at 10:15 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi deutschg,
There is no reset that can be done and possibilities of it is happening are
1. Faulty switch.
2. Faulty contol unit.
3. Bad door glass runchannel.
If the movement of the glass is slow when going up, it could be due to bad runchannel causing too much restriction and the auto function reversing. However it should not happen if you use the manual option instead of auto function. Pull the switch slightly to use manual winding up and see if it is ok.
NED5
Firstly, thanks for all the great info here....I was able to troubleshoot many problems thus far!
Here's my current one. The rear passenger power window does not work from either the main panel,switch on the drivers door or from the switch on the rear passenger door.
Here's what I've done thus far:
- checked all fuses. Originally the fuse for the rear window was blown, but replaced with a known working fuse.
- removed door panel and confirmed that window motor works when connected to a power source.
- replaced window switch with one from the other side to ensure it's not a switch issue.
Now I'm stuck. What should I do next?
CARADIODOC
  • 34,309 POSTS
There's actually four switches involved. Two are in the passenger's switch and two are in the driver's switch. The clue it's a switch problem is the window will work in both directions but possibly only from one switch for one of those directions. Start by checking for broken of frayed wires between the two door hinges.
FREEFORTHEE
I own a 2002 honda civic sedan lx. The front passenger window, and both rear passenger windows do not roll up or down, they stoped working. Each window failed one after another, within a short period of time. So I cant open them from the main switch or at their individual switch. The drivers window does function perfectly. Whats the problem?
Thanks
Start by having the window master control switch checked and tested all the power to the other windows comes from the master control switch-start here could als be a door control module failure
HONIBABE
I had my automatic transmission swapped out to a manual. Now my power window on the front passenger side stopped working, as well as my reverse lights and my blinkers. Did the mechanic forget to wire something properly?
KHLOW2008
  • 41,814 POSTS
Hi Honibabe,
Yes, some wires had not been done correctly. Manual and automatic have different wiring for the reverse lights .
As to the other components not working, test would have to be carried out.
OADIAZ
I have the car listed above LX model that I bought used. The passenger window would not work. It kept blowing its 20 amp fuse, so I replaced the regulator, master switch, fuses and both driver and passenger door harness to no avail. I recently noticed that the interior light will not come on when opening that door only. Lastly the driver door speaker would not work either. Could it be something in the interior fuse box under the dash?
Thank you ahead of time.
v/r
Osman Diaz
DANNY L
  • 5,648 POSTS
Hello, I am Danny
Just a quick question first. Have you checked the were the wiring assembly/harness that passes through the door to car body? It sounds like you might have a pinched wire or bad Ground. Hope this helps and feel free to ask any other questions.Thanks for using 2CarPros.
Danny-
OADIAZ
I have Danny, I've actually replaced both harness to both doors with same result. Not sure where to go from there.
  • 54,350 POSTS
Here are the window wiring diagrams so you can see how the system works. There is a window relay that needs to be checked here is a guide and the location of the relay.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Cheers, Ken
YANGJY26
Electrical problem
2000 Honda Civic 4 cyl Two Wheel Drive Manual
My D/S power window has trouble going up and down and is keeps comin off the track. Also my P/S window is slow to going up and down. My sunroof won't close and i have a on tilt.
Jan 4, 2021 at 10:16 AM (Merged)
KHLOW2008
  • 41,814 POSTS
The runchannel rubbers have hardened restricting the movement of the glasses.
Get a silicone or wax based spray and apply to the runchannels, should make the glass move faster and remain on track.
CALIKEL
Electrical problem
1999 Honda Civic 4 cyl Automatic 149600 miles
I have a 1999 Honda Civic LX 4-door sedan. I have recently come across the problem regarding the door locks on my passenger side (both front and back). When they are locked either using my alarm or driver side lock, they sometimes go down/up all the way to the lock/unlock position, and sometimes they don't. The driver side door locks work fine.
Also the back window on the passenger side does not go up or down at all. Neither the switch on the driver side or the actual switch for the window work. At first, it was temperamental and would work when it wanted to. Now it' doesn't respond at all.
Can anyone tell me possible causes and how much it would cost to fix these three problems???
Thank you!!
Jan 4, 2021 at 10:17 AM (Merged)
F4I_GUY
  • 3,302 POSTS
The lock issue could be the lock actuator in the door itself.
And the window issue is most likely a window motor. Try hitting around the bottom of the door panel while pressing the window switch to see if it works.
You are looking at a couple hundred dollars for each job.
JAKETN
My back right window is not working but all the rest is. I've check to see to see if it had any power but no . Could it be my main switch at driver side door be bad?
BMRFIXIT
  • 19,053 POSTS
Hold the switch in the up or down position and test if still no power check at back of the switch and if still no power then switch no good if you have power at the switch but not at the motor check wiring in the door jam
FAVI90
Windows wont shut nor close, i think its a technocal problem?
Jan 4, 2021 at 10:18 AM (Merged)
F4I_GUY
  • 3,302 POSTS
Does it move at all? Do you hear any noises?
Try holding the switch down or up and hitting the lower front of the door panel. This might jar the window motor into functioning again.
Regardless, you might need a motor and regulator.
PRIINCESS
The window has been acting up and I assumed it was the motor so I took the door panel off and I saw that the window was of trck wen I put it back on track and plugged the door back into the switch part it doesn't work! I tried to test the power going to through the connectors and the one going to the motor and my door speaker are not showing and any power to them! I have replaced the motor and checked the fuses! What else could the problem be? I need to know asap my window is rolled all the way down and I need it to go back up atleast!
Check and test fuse no.11 and also the window control unit
https://images.2carpros.com/forum/automotive_pictures/12900_honda_civic_window_problem_1.jpg
Jan 4, 2021 at 10:19 AM (Merged)
FELI_510
Electrical problem
1996 Honda Civic Front Wheel Drive Automatic 156400 miles
My front passenger window as well as my drivers side rear window are not working correctly. Most of the time I cant get them to roll down, if they do get rolled down I cant get them to go back up. Is there any way for me to manually roll the power windows up when they get stuck down?
KHLOW2008
  • 41,814 POSTS
Hi Feli_510,
Either the switches are bad or the motors are weak.
If it is the switches, the only other way you can roll them up is to remove the door panel, disconnect the motor wire socket and apply battery voltage to the motor to wiind up or down.
If motor, you can try vibrating the door panel to get the motor working.
TERRAPINWILL
I have a 1995 Honda Civic LX 4 door with about 180K. Just a few weeks ago the power windows stopped working. All the fuses are OK...any ideas why this happened? Can I fix it? Or do I have to go to a dealeshipr?
BRUCE HUNT
  • 3,754 POSTS
If they all stopped I would check fuses, then I would look for a relay, probably in the fuse box. don't forget to look under the hood at the fuse box. The driver door is the master and the problem will likely be found here.
Blown fuse #14 (20 amp) under the hood. Or the relay is bad. Test and replace if Black on Yellow or White on Red wire is open. Try another relay in its place.
SIMONESANMIGUEL
Electrical problem
1995 Honda Civic 4 cyl Front Wheel Drive Manual 190+ miles
Hi-
I have a 95 Civic, 2 door EX that as of a few days ago the power windows stopped working. I looked at the fuses and changed out a blown fuse and changed out another fuse that had the wrong amp. ( my power door locks do not work- previous owner said he couldn't fix so I have only locked car with key since I've owned) the over amp. fuse was for power locks so I borrowed that fuse to replace blown fuse for windows.
That worked initially but window power went out a few hours later. Perhaps once I turned off engine it reset, if thats possible?
Fiddled with fuses again- check all fuses and no blown fuses. The fiddling worked again for a few hours and then power windows stopped working again. Am I missing something?
I'm a girl- I have basic mechanical experience - changing tires, fluids, oil.. fuses and light bulbs but i'm not afraid to get under the hood so does anyone have any suggestions that I can try that aren't very complicated?
Thank you for your time,
Simone
F4I_GUY
  • 3,302 POSTS
The second time when you fiddled with the fuses what exactly did you do?
If you replaced the fuse and it worked that means that the fuse was blown and you have a short in the circuit somewhere. It may be the window motor drawing too much amperage or a wire that has shorted out.
If you just wiggled it back and fourth you may have a loose connection at the back of the junction block (fuse box) or it may be a corroded connection.
TISHAANN
1993 Honda Civic 4 cyl Manual 215k miles
For a while now my windows have had problems going back up. They would go down just fine at a normal speed. But going up, they're slow 'sometimes', having to wait long periods of time moving a quarter inch every 30 seconds. Sometimes going up 'fairly' normal, just slightly slow. This is both door windows. But just the other day after my car got a teeny bit rained on w/ the windows down, the driver side window wont go down. I got it back up right when the rain was coming down, but now it wont budge. Also have a problem with the sunrooof opening & closing as well. The sunroof will open, but I have to push upwards to lift it a lil to get it moving. Then when the sunroof closes completely or gets completley open it makes a high pitch squeal as I hold the button. Sometimes it also acts like it doesn't want to close. The problem seems to be worse when theres dew outside or when its been raining. I haven't had them checked for anything yet. Read it could be a fuse/motor/regulator/told something called pigtails. I'm trying to go the shortest route without having to fix everything b4 I find out what it is. What I'm wondering is if the fact that its all 3 could be a sign of something or maybe a symptom that could point me in a direction to start.
CARADIODOC
  • 34,309 POSTS
Hi TishaAnn. Welcome to the forum. Can't say for sure about the sun roof, but since the windows work in one direction, the motors, wiring, and fuse are ok. A real common problem is the track weatherstripping gets gunked up. The easy fix is to spray the tracks with Silicone Spray Lube. Roll the window down, then spray the lube inside the rubber channels on the sides and let it run down along the edges of the glass. It looks like water but will evaporate quickly and leave a very slippery residue behind.
In the rare event this doesn't help, check for frayed wires between the door hinges. As the strands break, the wire becomes smaller and is unable to carry the amount of current necessary to run the window motors. On cars where the window switches are in the door, all windows have a circuit that goes back through the driver's door hinges and switch assembly. A frayed or broken ground wire or feed wire will affect all windows. A broken window return wire will affect just that one window. The same is true about the motors. A defective motor will only affect that one window.
caradiodoc
NICKSAWYER
My rear left window has stopped working completely. It was working fine until all of a sudden it went down bit by bit, stopping and starting randomly and once it was completely down it wont go back up. Ive tried taking the trim off and pushing the window while holding the switch however it still doesnt budge. All three of the other windows are still working perfectly and the central locking on all doors is also.
MMPRINCE4000
  • 8,548 POSTS
Take the panel off again, measure voltage at window motor while depressing the window switch. If you have voltage at harness connector then most likely the motor is bad. If you have intermittent voltage, then window switch.
The other possibility is the window regulator assy. is binding. Try some white lithium on all joints of regulator, and inspect window track for breaks
NICKSAWYER
Thanks mmprince4000,
I forgot to mention i had already replaced the electric window switch because i originally thought that was the problem.
I was wondering if it were possible to somehow force the window up and leave it up without having to buy a new motor? I really couldnt care less if it worked or not, i just need it up.
Thanks in advance,
Nick
MMPRINCE4000
  • 8,548 POSTS
You will still have to remove the interior panel. Then use motor drive gear to roll up, disconnect connector at motor.
If motor still turns, use tape to immobilize shaft.
But if motor is bad, you can find one at junk yard for a few bucks, then you have a working window.
THAD20
I have a 96 Civic ex: The passenger side window will not go up. The switch on the drivers side will is working. However the drivers side control will not let up the passengers side
  • 31,937 POSTS
Hi there,
You will have to remove the door trim to access the window motor. Test power at motor loom plug, There should be power on one side of the switch when in going up, and power in the opposite terminal when going down, If this is ok the problem is in the motor or regulator assembly.
Mark (mhpautos)
Jan 4, 2021 at 10:20 AM (Merged)
CYBERWATSON
  • 5 POSTS
My passenger side (power) window stopped working about a week ago. I had replaced the driver side regulator & motor about 1 yr ago, so I replaced the passenger side regulator & motor but still doesn't work. I checked both the drivers side & passenger switches with continuity tester & checked the fuses but didn't find any problems with them. I thought I'd ask to see if you're aware of any power window issues that are typical with these cars.
Jan 7, 2021 at 10:30 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi cyberwatson,
There are no issues with the power windows as far as I know of.
Did you test if the motor is working?
Did you test for power supply?
CYBERWATSON
  • 5 POSTS
Unfortunately, I'm not real good with electrical testing. I have a multimeter and am trying to figure it out. Is there an easy way you can recommend to tell if the motor works?
