A/C not working?
2006 HONDA ACCORD
180,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
NPOLCHES82
  • 6 POSTS
My uncle had overcharged the system and now failed. I had vacuumed, replaced the low/high pressure sensor, relays and recharged. compressor does not engage. I have no power going through the cable to the compressor. I ran a jump wire from battery to the cable to compressor and didn't seem to click. Not sure what else i could try. It ran awesome before until it was overcharged. I checked the DTC self check on the radio control panel and came up with K and O problems also.
Aug 31, 2019 at 9:24 AM
  • CAR REPAIR CONTRIBUTOR
Good morning,
Even with it overcharged, there are safety features built into the system from damaging the components.
How much voltage is at the wire to the compressor with it on?
I will attach a wiring diagram for you to follow for the system.
Aug 25, 2020 at 1:20 PM
NPOLCHES82
  • 6 POSTS
I checked it out with a light tester. i dont have a voltage meter. I did try to jump it from direct battery and no click sound. Am i supposed to add a ground also to the compressor? all i did was use a power wire.
Is it a 2 wire connector or 1 wire?
If it is 1 wire, no ground needed.
NPOLCHES82
  • 6 POSTS
it is a 1 wire. i put the light tester to it. but nothing. i got a get a voltage meter. all fans come on when A/C button is pressed.
Aug 25, 2020 at 1:21 PM
Check the fuse I circled in the diagram for power on both sides with the key on.
NPOLCHES82
  • 6 POSTS
All fuses, relays are good.
NPOLCHES82
  • 6 POSTS
When I hit the A/C button. Cars rpm's dropped a little like it wants to engage. But nothing.
So the compressor did not engage when you jumped it? If that is true then you have a failed compressor.
NPOLCHES82
  • 6 POSTS
Yes, I took a power cable from battery to the wire from compressor and nothing.
Okay, you have a failed compressor.
DON-HARRIET
  • 5 POSTS
Air conditioning problem when on max cool driver side air is warm while passenger side is cold with dual temperature output turned off. There are no DTC codes and the sensor codes were:
1. 33.
2. 29.
3. 02 in shade 35 in sun.
4. 73.
5. 32.
6. d1 on low 99 on high temperature.
7. 01 on low 99 on high.
8. 00.
9. d0 on low 44 on high.
#9 (vent temperature air out) may be the problem - but why would it only affect the driver side?
All of the air-mix motor looked okay ( I actually removed the drivers side to verify the cable and lever were moving properly) and the heater valve seem to open and close okay.
I tried slowly turning the temp (about one degree every two seconds) to max, then slowly turning it to low three ways:
1. Both sides the same (dual off).
2. Driver side only.
3. Passenger side only.
Results:
1. When at max - equally hot air from both sides. At minute passenger side cold, driver side about the average temperature of the car.
2. Passenger side stayed cold - Driver side hot at max, avg car temperature at minimum.
3. Driver side stayed at avg car temperature - passenger side hot at max, and cold at minimum.
Has anyone else seen this problem? Better yet resolved it?
Dec 17, 2020 at 10:21 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi don-harriet,
It sounds like one of the blend door actuators is not closing completely.
Here is a guide that will show you what you are in for when replacing them and testing the air door operation:
After going through the data provided, I suspect the air mix door to be stuck in driver side or is leaking.
Here are the blend door locations: Mix, Mode and recirculation.
Check out the diagrams (below).
Cheers
DON-HARRIET
  • 5 POSTS
I am a bit confused. Is the air mix door controlled by the air mix control motor? When I pulled the driver side air mix control motor and moved the lever by hand, I got the range of ambient air (full up) to hot air (down position). Is the "air mix door" different from this?
KHLOW2008
  • 41,814 POSTS
Yes, the motor controls the air mix door.
There are sponges to act as seals and this could be worn causing the cool air to be heated up when travelling to the air vent.
DON-HARRIET
  • 5 POSTS
I guess this means that the vent system itself needs to be taken apart to repair/replace these sponges. I am surprised that the service manual does not really cover this problem other than the vague picture on 21-86. How is this corrected?
HAGERGF
EX model with dual zone climate control. On a recent long drive in 90+ degree temps the air conditioner was struggling to cool the car. I noticed that the air vents on the drivers side of the vehicle were blowing warm air while the AC is on but the passenger side is blowing cool (not cold). I put my hand on the center vents and could feel a noticable difference between passenger and driver side air. The dual climate control was set to the same temp for both sides of the vehicle and even when I set the driver's side to it's lowest setting nothing improved. The blower appears to be functioning properly by increasing in speed when a lower temp is input. Any ideas what the problem might be?
KHLOW2008
  • 41,814 POSTS
Hi hagergf,
Honda has a self diagnostic built in the climate control system but I do not know if it works for your model
1. Turn ignition switch on.
2. Turn AC on in Auto mode.
3. Wait for 1 minute on temp display at 18 degrees.
4. Push AUTO and OFF together.
5. If any indicator lights are showing on the control panel, something is wrong, let me know what it is and I will try to get the answer.
KHLOW2008
  • 41,814 POSTS
You mentioned no DTC's, was it scanned or you used the system self diagnostic?
AGG2
The diagnostic dosnt works, .no codes in my accord EX 2005, .. Conditioned Air dos´nt works propperly. rigth side its (cold) ok, ..left side is warm, ..... Im in México city, ... thanks. I hope you tell me somthing to do.
DON-HARRIET
  • 5 POSTS
I used the built in self diagnostics. I got no codes, not even any blinking. so I tried it several times. I turned the ignition switch on, the pressed the "auto" button, while holding the "auto" held down the "off" button. To make sure I held it for about two minutes, no codes.
KHLOW2008
  • 41,814 POSTS
Hi agg2,
You won't see any codes. You would only see the indicators on the air modes showing. eg. Air flow to upper, air flow to legs, A/C on, A/C off, fan speed at minimum, fan speed at maximum, fan speed at 2nd point only.
If there is none, you need to check for dislodged or stuck air mix vent linkages.
KHLOW2008
  • 41,814 POSTS
Hi don-harriet, Try disconnecting the battery negative terminal for ten seconds and try again. If it did not work, try this and see if there is anything on record. How to retrieve a dtc (without hds): The audio-HVAC display panel has a self-diagnosis function for climate control. To run the self- diagnosis function, do the following: 1. Turn the ignition switch ON (II). 2. Set the driver's temperature control dial or button on MAX Cool. 3. Press and hold the OFF button. 4. While holding the OFF button, press the rear window defogger button five times within 10 seconds. The self-diagnosis will begin. Locating Auto Button And Off Button (Without Navigation System) Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://images.2carpros.com/forum/automotive_pictures/192750_HVACButton06Accord_1.jpg
Locating Auto Button And Off Button (With Navigation System) Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://images.2carpros.com/forum/automotive_pictures/192750_HVACButton06Accord02_1.jpg
If there are any problems in the system, the temperature indicator will light up the segment (A through Q) corresponding to the error. The temperature indicator will then alternate every second between displaying "88" (all segments lit) and the error code segment (A through Q). NOTE: The system will only display the DTC when the AUTO and OFF buttons are pressed. If you release the buttons, the display will go blank. To return the display, simply press the AUTO then the OFF buttons again. If no segments light up, the system is still not operating properly, check the sensor inputs to the climate control unit, or refer to SYMPTOM TROUBLESHOOTING INDEX . Fig. 9: Identifying Drivers Temperature Indicator Courtesy of AMERICAN HONDA MOTOR CO., INC. Fig.
https://images.2carpros.com/forum/automotive_pictures/192750_HVACButton06Accord03_1.jpg
10: Identifying Passenger's Temperature Indicator Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://images.2carpros.com/forum/automotive_pictures/192750_HVACButton06Accord04_1.jpg
Cancelling the Self-diagnostic Function 5. Turn the ignition switch OFF to cancel the self-diagnostic function. After completing repair work, run the self-diagnostic function again to make sure that there are no other malfunctions. Page 1 of 1 CLIMATE CONTROL (EXCEPT HYBRID & V6) -2006 Honda Accord EX 9/5/2008
DON-HARRIET
  • 5 POSTS
I got no DTC error codes following your instructions.
I disconnected the battery needed to enter the security code and reset the clock, but no change in the A/C.
I re-ran the DTC test - no errors again.
KHLOW2008
  • 41,814 POSTS
Hi again,
Looks like you have to check the control unit or the internal linkages for fault.
OLUSHOLA
Hello All. I guess this reply may be late. Nonetheless, I still want to give it all the same. I experienced the same problem with my 2006 Honda Accord EX-L four cylinder. When the AC was on, the passenger output was cold while the driver's side was hot. I confirmed that the air mix control motor was working correctly. Then, I removed the cabin filter under the glove box and I found it very dirty. I cleaned this filter and topped up the refrigerant. Now the problem is solved. In case you have this same problem, you may wish to try this simple solution. Thanks.
  • 54,354 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Here is the way to change the cabin air filter, this will give you an idea:
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
This is how it is done on your car (below).
Cheers, Ken
JOHN DIBELLA
i replaced the blend door on the drivers side. I am still getting cool air on that side. The passenger side is blowing A/C. What else could it be ?
Dec 17, 2020 at 10:22 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
Have you checked your climate control display for any Heating Ventilation Air Conditioning (HVAC) Direct Trouble Codes (DTC)(s) yet? I have included the directions for pulling them up in the diagrams down below. Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
