2004 Honda Accord Repair Question
Asked on October 14, 2008
2004 Honda Accord Power Outlet
Electrical problem
2004 Honda Accord 4 cyl Front Wheel Drive Automatic 58,101 miles
How can the power outlet in my car be fixed?? When i plug my charger into it doesnt work. I tried replacing the fuse and still nothing happens. What can I do?
Answer
Replied on October 20, 2008
Hi missnay1121,
You need to check if the charger plug is compatible or good. some plugs might not be getting the proper contact to work.
Test for power supply to centre pin of power outlet, if no power, either the socket or fuse is bad. If socket, you need to replace it.
