My brake lights are not working?
2009 HONDA ACCORD
27,000 MILES • 4 CYL • FWD • AUTOMATIC
ADAMKOPCHYAK
My brake lights are not working? There are two (2) wires (black and red) for the bulb but I don't know how to fix it can you help me?
Mar 14, 2010 at 8:43 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
It sounds like the #10 fuse in the under hood fuse panel is out or the drives MICU is out. But let's start with the easy stuff, here is a guide to help you check the fuses witht he fuse location in the diagrams below. I have included the brake light wiring diagrams and fuse locations so you can see how the system works.
https://www.2carpros.com/articles/brake-lights-not-working
and
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Mar 17, 2010 at 9:36 AM
MUDDLEPUP
I've been having trouble with my brake light not coming on?
May 17, 2021 at 12:01 PM (Merged)
KHLOW2008
  • 41,814 POSTS
It can be the brake light switch I just had this problem with a this car in the shop here is the switch location so you can change it out. Check out the diagrams (Below). Please let us know what you find.
BMANION
All of my lower brake lights are out at the same time but the upper brake light is okay. The filaments in the brake lights look okay. All other lights and electrical are okay?
KHLOW2008
  • 41,814 POSTS
Hi bmanion,
It sounds like the turn signal hazard relay is not working correctly but to be sure here is a guide to help test for power with the brake light wiring diagrams along with the turn signal relay below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
ZANYJB
Thank you for this post I had this problem and had to get a new flasher relay cost me $65.00 all fixed I love this site.
LITTLERASCAL
Looking at the manual it does not indicate which fuse is used for the "brake lights." Without pulling every fuse how do I tell which one I should be checking.
F4I_GUY
  • 3,302 POSTS
You should check each fuse with a test light or multimeter. Sometimes the fuse schematics does not list every circuit that is on that particular fuse so it is always best to check all of the fuse.
Here is a guide to help you see how to check the fuses
Here are the fuse panel locations and identification
Cheers
JENN822
We've checked the fuse... it is the same one as the horn. The fuse is fine and the horn works. All other lights work on the tale light. The brake lights just won't work. Help.
  • 31,937 POSTS
Hi there,
Check the brake light switch at the top of the brake pedal, remove plug and check for power and if OK bridge out plug with a paper clip or split pin and check for lights, if OK replace switch.
Mark (mhpautos)
ANNIE KAVENEY
Brake lights don't work but running lights are working.
Good afternoon,
I attached a wiring diagram for you to view. You need to test for power to the brake light switch. In most cases, it is the switch that is bad.
1. Disconnect the 4P connector (A) from the brake pedal position switch (B).
2. Check for continuity between the No. 1 and No. 2 terminals.
There should be continuity when the brake pedal is pressed.
There should be no continuity when the brake pedal is released.
3. Check for continuity between the No. 3 and No. 4 terminals (with cruise control).
There should be no continuity when the brake pedal is pressed.
There should be continuity when the brake pedal is released.
4. If necessary, adjust or replace the switch, or adjust the pedal height.
WSP690
The brake light indicator is lit up on the instrument cluster on the dashboard. Is it a sensor and how do I replace it?
RGAYER_4484
This means you have a brake light out here is a guide to help walk you through the bulb replacement and diagrams below to show you how on your car.
May 17, 2021 at 12:02 PM (Merged)
G.SMOTHERS
tonight I noticed that I have no brake lights at all. I do have marker lights....turn signal.....back up .....etc I checked the fuse and looked for any disconnected wires, but didn't find anything. Could I have a bulb out that is causing them all not to work? Any help would be appreciated.
BRUCE HUNT
  • 3,754 POSTS
i suspect and would check the brake light switch on the brake pedal.
G.SMOTHERS
Bruce- I replaced the brake light switch and I'm good to go. I really appreciate the help. :D
TELLISRODGERS
brake lights wouldn't go off and turning signal stop working
BRUCE HUNT
  • 3,754 POSTS
Start by looking at the switch on the brake pedal. If the brake lights are always on, I would suspect that you cruise control does not work either. The switch can be tested with an ohm meter.
TELLISRODGERS
it was the brake light switch thank you
COLSEN09
Have no brake lights at all. The fuse blows instantly l, as soon as I put it in the fuse box. Have changed the brake light switch. Checked bulbs done all obvious tests..
CARADIODOC
  • 34,309 POSTS
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a 12 volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it's not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
TATARIE
I recently bought a 1991 honda accord. the passenger side brake light didnt work, so i replaced the bulb..and it still doesnt work. could it be the wiring? how do i fix this?
KHLOW2008
  • 41,814 POSTS
Hi tatarie,
If the bulb socket is rusty, it would not provide good conductivity and the spring might be stuck resulting in the bulb not seating properly.
Is the bulb used correct? Double filament type.
The right and left are connected in parallel, so it should be the wiring at the taillights only.
