Heater blows cold air
JUST ME AND YOU
  • 2007 CHRYSLER PACIFICA
  • 4.0L
  • 130,000 MILES
When I warm my car up in the winter or we are sitting at a stop light my car only blows cold air why? The temp gage is fine and runs great just need heat to warm up the inside when it is -30 wind chill. Please please help thank you in advance..
Saturday, January 25th, 2014 AT 7:37 PM
HOMER1967
  • 875 POSTS
It sounds like you have a low coolant level. Does it blow heat at highway speed? If you turn the control from hot to cold can you feel a temperature change in the air coming out. With the car sitting still fully warmed up try reving the car up in short quick burst, like vroom wait vroom wait for about 3 or 4 minutes and see if the air gets warm.
Here is a guide that can help as well
https://www.2carpros.com/articles/car-heater-not-working
Sunday, January 26th, 2014 AT 12:30 PM
JUST ME AND YOU
Thank you so much I had coolant leak and didn't even know it, once I replaced the radiator the heater started working again. I love this site.
Sunday, January 26th, 2014 AT 1:58 PM
HOMER1967
  • 875 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Sunday, January 26th, 2014 AT 5:28 PM
KERRY2112
  • 4.0L
  • V6
  • AWD
  • 120,000 MILES
This winter I've noticed that the when I need the heat on, it doesn't ever get hot, even if I'm driving for an hour, it's just luke warm. When I put the defrost on it's cool, even when I let it run for at least fifteen minutes. I did have the radiator replaced a few months ago and they did remove the bars leak sealer. I also had the coolant flushed a few days ago but that didn't make a difference. Any advice would be appreciated.
Thursday, February 28th, 2019 AT 1:30 PM (Merged)
  • 108,192 POSTS
Heat can only be lost for a few reasons. However, I need to ask a few questions to know which way to go.
First, does the engine warm up to a normal operating temp?
Second, if it does, allow the engine to warm up and have the heater on high. Feel both heater core hoses that under the hood. They are smaller hoses (aprox 5/8"ID) and one goes from the water pump to the heater core via the firewall under the hood. The other will look the same but go either from the thermostat housing or engine block to the firewall. If the engine is warm and the heater is on, both should be hot.
Do that and let me know what you find. That will determine what needs done.
CJ MEDEVAC
  • 11,004 POSTS
Let's make sure the heater hoses entering the firewall are hot when your rig is at operating temperature
if not, it's possible the heater core is stopped up (no circulation) taking the hoses loose and pushing water from your garden hose in both directions thru the core may unstop it
i did not find any sort of control valve in "prodemand", (there could be one!) That might "shut off" flow thru the system. So if it ain't pushing water ezily, be weary that there might be a valve preventing this operation
i'm banking on your hoses being hot, and the above procedure is not necessary!
There are blend doors within the unit that may be "stuck/ broken/ or the actuator just ain't-a-workin' to move them"
check your fuses, connections, this might be a power problem
the actuator itself may be inoperable
with a large (am I pretty!) Hand mirror and a good flashlight, you may be able to see the actuator (and whether it moves or not) when you move your controls.
According to "prodemand" you may have both a driver's side and passenger side door. I clicked on 3 different "figures" to see if they had multiple views (the same ole diagram came up each time) i'm posting the diagram below for you to click on
i hope this aids you
the medic
2CP-ARCHIVES
  • 4,542 POSTS
  • 10,900 MILES
I have no heat. My husband took my Pacifica in to get a leak fixed. There was a crack in the radiator so they put sealant on it. Then suddenly no heat! - Fan is blowing, air conditioning works, no heat. So I took to a dealership and they replaced the radiator and the thermastat. Still not good heat but a little better (off and on but not warm enough to warm the vehicle or defrost). I need help.
  • 52,797 POSTS
Sealer is always a bad idea as it sludges up the system.
It sounds like the heater core is clogged with debris and needs to be power flushed
KIKEVICTORIA
  • 2005 CHRYSLER PACIFICA
  • 6 CYL
  • 4WD
  • 52,000 MILES
No heat cold air only
Check the thermostat, heater core and air blend door-
BLACKWIDOW90
The front heat is not blowing but the rear blows but no heat
HMAC300
  • 48,601 POSTS
Check to see if actuators are working and check relay and fuses. Generic pic for actuators inclosed.
