2CarPros - Car Questions & Answers
2002 Ford Windstar Repair Question
Topics covered: Door, Dealer, Fuse.
Asked on March 24, 2008
2002 Ford Windstar Passenger sliding door
Our passenger door on the driver side would not close. It would slide almost to the closing point, then slide open. I pushed down the button beneath the window to lock the door and the door slid shut, but now it's permanently locked and we can't open the door. The dealer wants $795 to repair it. The fuse appears to be okay since everything else on that fuse is operational. I tried to pull up the lock button with pliers, but it won't budge. I removed the cover on the door handle, but couldn't see inside the door much. Can you help? The dealer's anaylsis (I paid $90 to have him look at the problem) is "RL sliding door latch and actuator + woring asse and need to adjust door assts and readvice" (I couldn't read the handwriting well--worse than a doctor's).
Thanks
Avatar Asked by BOOPAH
Answer
Replied on March 25, 2008
the dealer is probly right the accuator is a little motor on the latch that locks the door and they freeze check the junk yard for a used one then take the door scin off to dissengae the rod so you can open it and replace the latch assembly
Tiny Answered by master tech dan
0 questions asked
