2CarPros - Car Questions & Answers
1995 Ford Windstar Repair Question
Topics covered: Sensor, Spark, Abs.
Asked on July 15, 2010
1995 Ford Windstar
1995 Ford Windstar
Okay this is a weird problem we've tried everything and can not find the cause so maybe you can help.When you first start it it does fine and after it warms up it suddenly balks and sputters but after it starts balking and sputtering it keeps doing it.I need help
Avatar Asked by Mandielynn2010
Answer
Replied on July 16, 2010
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Tiny Answered by rasmataz
68 questions asked
