2CarPros - Car Questions & Answers
1994 Ford Thunderbird Repair Question
Topics covered: Battery, Fuse, Starter.
Asked on October 2, 2007
1994 Thunderbird Has Me Puzzled!
1994 thunderbird, 3.8, auto,..NOT SC...ok-
just swapped tranny...completed this and car started and ran great for two weeks...alternator stopped charging so i just swapped that out...now immediately I hopped in to start her up to make sure this BRAND NEW not Rebuilt Alt. was charging and that was that and.........turned key, very quick like split second churn by the starter and then ALL of the car lost its power from the battery...no lights no nothing, car is completely dead...now, i checked all fuses and relays- OK- while i was standing there PUZZLED with the doors open, all of a sudden the Interior lights kicked on???? Now can you say HAUNTED? just kidding...so I happily climbed in and turned the key again...SAME RESULT...starter cranked for a split second and car lost ALL ELECTRICAL FLOW THROUGHOUT...any suggestions>?
http://www.2carpros.com/forum/automotive_pictures/104074_7ef1c6c91ec7dd47b0ae045ea02cf150_1.jpg
Avatar Asked by 94T-BirdGuy
Answer
Replied on October 8, 2007
CHeck the connections on the side of the fuse box under the hood. Wiggle the wiring as you go to check for shorts. Next (if you have not already checked the battery connections do so 4 corrosion and tightness) CHeck 4 loose or corroded grounds.
Sounds like you have a bad connection.
______________________
I try to answer questions as though it were my car, like I’m standing in your shoes looking to diagnose the problem.
Tiny Answered by poet042005
14 questions asked
