2CarPros - Car Questions & Answers
1990 Ford Tempo Repair Question
Topics covered: Spark, Battery, Engine.
Asked on April 1, 2010
1990 Ford Tempo
Engine Mechanical problem
1990 Ford Tempo 4 cyl Front Wheel Drive Automatic 99000 miles
I have a 1990 ford tempo that will not start. It will turn over good but won't start. I have replaced the fuel pump, starter, battery, spark plugs, ignition module, coil, cyclender, what else can I do to get it to run?
Avatar Asked by littlehawklt775
Answer
Replied on April 1, 2010
Ok, I don't see were you changed the Cap and Rotor. Take a look at the inside of the cap, look at the electrodes if they are covered with corrotion replace it and also replace the rotor.
Also not sure what CYCLENDER is.
Tiny Answered by obxautomedic (expert)
3,502 answers provided
Replied on April 2, 2010
did you check for spark at the plugs? do you smell gas at the tailpipe? when was the car running last? did it just suddenly quit?
Tiny Answered by fixitmr
24 questions asked
