PCM Location
JLOFFORD
  • 2003 FORD TAURUS
  • 125,000 MILES
Where is the PCM?
Thursday, January 6th, 2011 AT 2:44 PM
DOCFIXIT
  • 18,828 POSTS
The location of the PCM is in the engine bay at the firewall on the passenger's side. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, January 6th, 2011 AT 3:34 PM
DUG4TRACE
  • 2003 FORD TAURUS
Computer problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic
i need the location of the ecm
Tuesday, October 1st, 2019 AT 1:59 PM (Merged)
Powertrain Control Module (PCM) Right rear corner of engine compartment, mounted in firewall
https://www.2carpros.com/forum/automotive_pictures/12900_pcm_11.jpg
Happy New Year 2009
MHJ
  • 10 POSTS
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 130,000 MILES
I can't find the PCM. The Ford diagrams list it as module C175, and place it in the Engine compartment, rear, RH side. But the sketch is too vague for me to identify it. Is it attached to the right side of the engine? Or is it attached to the back side of the dash board. Where is the rear, RH side of the engine compartment? It is relative to standing in front of the car looking at the engine? Or from the driver seat?
See below
JDL
  • 16,098 POSTS
Under the hood, passenger side, firewall.
  • 108,300 POSTS
It is in the right rear of engine compartment mounted in the firewall. Here is a picture:
  • 108,300 POSTS
The left and right sides of the vehicle are as if you are sitting in the vehicle.
DGK55555
  • 2002 FORD TAURUS
  • 3.0L
  • 6 CYL
  • 75,000 MILES
4 or 5 trans codes displaying and car has been running fine for a year, however it will not pass inspection unless it gets fixed. Thinking about replacing ECM. Anybody know how difficult it would be?
Tuesday, October 1st, 2019 AT 2:00 PM (Merged)
HMAC300
  • 48,601 POSTS
Check battery for condition then check fluid level may be low and causing codes. weak batteries send false codes among other things.
DGK55555
Trans guy wants 1,200 to fix. Not sure I trust this him!
HMAC300
  • 48,601 POSTS
If he wants that much it 's probably in need of a rebuild check around at different shops and it's probably in the ball park.
PETREA
  • 2001 FORD TAURUS
  • 164,000 MILES
Engine light is on with code for keep alive memory, will not clear
DOCFIXIT
  • 18,828 POSTS
Right rear engine compartment. What was code?
PETREA
Code is P 1633
DOCFIXIT
  • 18,828 POSTS
Check fuse and make sure battery terminals clean and tight. Check voltage at pins on PCM see diagram
TAURUS-LOVER
  • 2001 FORD TAURUS
  • 6 CYL
  • 150,000 MILES
Where can I find a pinout (wiring) of the PCM? I want to know to which pins the four oxygen sensors are connected. Thanks, John
BMRFIXIT
  • 19,053 POSTS
What do you have trim and engine size?
TAURUS-LOVER
It's a 3.0L OHV engine. I don't know about trim. Btw, where is the PCM located? Thanks, John
BMRFIXIT
  • 19,053 POSTS
Give me few min and will try and get you the wiring harness
location and all
