Mechanics
CHECK ENGINE LIGHT
2003 Ford Taurus
Computer problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic
What do I need to check when I was told the check engine code says low fuel pressure?
Gjones9876
April 12, 2009.
Can you tell me the code that showed up in p**** foramt?
AD
Blackop555
Apr 12, 2009.
The codes are P1131, P1132, and P1151
Gjones9876
Apr 17, 2009.
P1131- lack of upstream heated oxygen sensor switch [ sensor indicates lean bank 1]
p1151-lack of upstream heated oxygen sensor switch [ sensor indicates lean bank 2]
most likely since both are showing lean I would go and clean the maf sensor with QD contact cleaner. Dont touch the wires or youll damage them. Just spray them with the cleaner. If thats not it check for a exhaust leak before the sensors.
Blackop555
Apr 18, 2009.
Thanks for your reply, would you tell me where the Maf sensor is located.
Gjones9876
Apr 18, 2009.
The MAF sensor is the mass air flow sensor. It is located right after the air cleaner box on the air hose going to the throttle body.
Blackop555
Apr 19, 2009.
AD
