2CarPros - Car Questions & Answers
2003 Ford Taurus Repair Question
Topics covered: Sensor, Battery, Check engine light.
Asked on March 16, 2008
2003 Ford Taurus Check Engine Light
I own a 2003 Ford Taurus V6 DOHC and my check engine light came on. I went up to the local Autozone in order to check the code which was P0141. This code is for the Heated Oxygen Sensor bank 1 sensor 2. I replace the sensor but check engine light is still on. I unplugged the battery and the light went off for about 10 min but it came back on. Went back to Autozone and still had the same code. Does the computer need to be reset by the OBDII scanner or does unplugging the battery reset the computer. Any other suggestions?
Avatar Asked by ram5er
Answer
Replied on March 16, 2008
May be a problem in the harness as one other possible cause. IF the sensor was a universal one as oppossed to the one meant for the system, that may have a bearing on it. There is a chart to troubleshoot this code that is best to follow before replacemnt of a suspected sensor. A code is a starting point to diagnosis and jumping from the code to a guess based on the description is gamble at solving the problem.
Tiny Answered by Service Writer (expert)
9,955 answers provided
Replied on March 17, 2008
Thank you for your quick response. fyi... I did not use a universal sensor, the one a purchase was for my Taurus. Where do I find the troubleshooting chart?
Tiny Response from ram5er
1 question asked
If you look on the link on my signature, it will take you to mitchell manuals.
IT will be listed under tests with codes.
