Where is the camshaft sensor located
DCSAUTOREPAIR2
  • 2003 FORD TAURUS
  • 175,640 MILES
Where is the cam sensor located?
Saturday, July 28th, 2012 AT 4:20 AM
WRENCHTECH
  • 20,758 POSTS
The camshaft sensor is located at the rear of the engine on top here is a guide to help walk you through the repair with diagrams below to show the location.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Saturday, July 28th, 2012 AT 10:10 AM
DEVILDAWG
  • 2002 FORD TAURUS
Hello!
I own a 2002 Taurus with 86,000+ miles on it. The engine is the DOHC V6 (Duratech 30, I believe). I have had an incresingly frequent problem with the engine misfiring, exasperated when a load is on the engine at idle (AC, defroster, etc). Had the codes pulled, and received a 0316 - camshaft position sensor (done at a national AP chain store). Seems to make sense, but I am having difficulty locating proper repair information for this problem. I am fairly confident that I can perform the repair myself, so long as I don't have to spend hundreds of $$$ on specialty tools. It is my understanding the part runs about $140, but that most often the culprit is simply the electronics at the top of the spine.
I would appreciate very much the input of an expreienced machanic on this issue. Thank you in advance for taking the time here.
Tuesday, August 6th, 2019 AT 3:44 PM (Merged)
MERLIN2021
  • 17,250 POSTS
According to Mitchell, no special tools on the DOHC models, only require a synchonizer on SOHC models!
https://www.2carpros.com/forum/automotive_pictures/62217_CamSensor_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_4.jpg
Just make sure the O ring is in place...
BNRITTEL
  • 2001 FORD TAURUS
Computer problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic
cant find the cam sensor to replace it, engine light came on and had a diagnostic test done and it said it was the cam sensor. Can't locate to replace it.
BMRFIXIT
  • 19,053 POSTS
12 v 3.0 engine rear of engine between the two heads
24V 3.0 engine left front of engine below valve cover
https://www.2carpros.com/forum/automotive_pictures/99387_cam_sensor_1.jpg
