2001 Ford Taurus Repair Question
Asked on July 14, 2010
2001 Ford Taurus hesitation loses power
Engine Performance problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic 138000 miles
after driving for awhile car start hesitating and loses power like its running out of gas. i can pull over turn it off and crank it back up and car runs fine. what could be the problem?
Answer
Replied on July 15, 2010
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
