I was told to replace my spark plugs
CAROLGILES
  • 2007 FORD TAURUS
  • 6 CYL
  • 49,000 MILES
My car wont start and I was told to replace my spark plugs. Where are they located?
Monday, October 25th, 2010 AT 10:52 AM
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Thursday, July 16th, 2020 AT 12:32 PM
KOLTERMAN_THOMAS
  • 2006 FORD TAURUS
  • 6 CYL
  • FWD
  • 69,859 MILES
How do I get to the back sprark plugs #s 1 2 3 and what would be the easy way
Sunday, May 23rd, 2021 AT 11:37 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
You don't have to remove the manifold you can get a few ratchet extensions with a little play in them taped together with spark plug socket and remove them
JOE THERIOT
  • 2003 FORD TAURUS
  • 6 CYL
  • FWD
  • 120,000 MILES
My engine is beginning to run badly as the car warms up and gets worse as the day gets hotter. It sounds like its running out of fuel. I am wondering where, if there is one, the crank sensor is, and the throttle position sensors are. I need to change the spark plugs and wires?
Sunday, May 23rd, 2021 AT 11:38 AM (Merged)
Here is a guide to help change the spark plugs
Crankshaft Position Sensor
2003 Ford Taurus V6-3.0L DOHC VIN S
https://www.2carpros.com/forum/automotive_pictures/12900_c1_42.jpg
2003 Ford Taurus V6-3.0L VIN 2 Flex Fuel
https://www.2carpros.com/forum/automotive_pictures/12900_c2_34.jpg
Throttle Position Sensor
https://www.2carpros.com/forum/automotive_pictures/12900_t1_26.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_t2_16.jpg
SEBUMSEBACEOUS
  • 2002 FORD TAURUS
  • 6 CYL
  • 95,000 MILES
How do I access the rear spark plugs on a 2002 Taurus; 6-cyl?
Sunday, May 23rd, 2021 AT 11:39 AM (Merged)
BLACKOP555
  • 10,371 POSTS
You may have to lossen up the motor mounts and tilt the engine forward to reach them.
TRACY1964
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 130,000 MILES
How's the easiest way to change the 3 back spark plugs
TORNADO
I did replace the spark plugs on my Taurus 02 without a problem. I did it with a 5/8 " extension and a normal Craftsman 8" wrench The one in the middle (back in the middle) is the one that takes a little more time. I recommend you to use original Motorcraft ones. I wanted to use another brand and it didn't work well.
ANDRES1234
  • 2001 FORD TAURUS
  • 6 CYL
  • 86,000 MILES
How do I change the rear spark plugs located at rear of engine at the fire wall.
Sunday, May 23rd, 2021 AT 11:40 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Its depend on you engine size
I am going to assume you have the one that need upper intake removed
or moved aside
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_117.jpg
OR
LITTLEDONNA
  • 2001 FORD TAURUS
How do I get to the 3 rear spark plugs on my 2001 Ford Taurus 24V-DOHC? They are the 1, 2, 3 pistons. What is the best way to change those plugs?
BLACKOP555
  • 10,371 POSTS
Some claim to be able to remove the windshield wipers and the wiper cowl. and maneuver to it. but when i do it i always remove the upper intake manifold and reach back behind it and do it from there. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
CHRIS R INGLES
  • 2000 FORD TAURUS
  • FWD
  • 159,000 MILES
I am replacing the spark plug in my 2000Taurus, 3.0 vulcan motor. I have replaced the front 3 but how do you get to the back 3?
Sunday, May 23rd, 2021 AT 11:41 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Remove Upper intake manifold removed for clarity. Remove the ignition coil-on-plug. Disconnect the electrical connector. Remove the bolt. Remove the coil and plug.
COCO08
  • 1999 FORD TAURUS
The diagnostic reading showed that I had three spark plugs that were misfiring. The mechanic says that it will take two hours to replace spark plugs because the back three are located behind the manifold. My boyfriend says that he can replace them but I was leary about letting him take the manifold apart. Is this a simple process?
FLEXY5
  • 512 POSTS
You shouldn't need to remove the intake to do this, unless it is the taurus SHO. The 3.0 vulcan engine has enough space to reach back from the sides. You can't see them, but you can feel them. This is why it takes so long to do. It's just time consuming and sometimes frustrating. The most he would have to remove is the air intake tube. Two can be reached from the driver's side, the other from the trans side. Good luck, let us know if you need more help.
2CP-ARCHIVES
  • 4,542 POSTS
  • 1999 FORD TAURUS
  • 160,000 MILES
I was told about a month ago that I need to get my spark plugs and spark plug wires changed. Problem was they wanted to charge me Almost $20.00 per spark plug and another $80.00 for the wires. And on top of that $200.00 in labor. I went and got the parts online but haven't had a chance to take my car in to get the stuff changed. Can you help me?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car:
COUPLE4CHRIST
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 178,000 MILES
I am replacing the spark plugs and wires on my 99 taurus and I need to know how to get to the back three spark plugs. Any suggestions?
Thanks
Ben
Sunday, May 23rd, 2021 AT 11:42 AM (Merged)
