Where is the ecm located
1997 FORD TAURUS
DAVE233
Computer problem 6 cyl Front Wheel Drive Automatic 110000 miles
i think i've damaged the ecm while replacing the alt. i had a bad short because i didn't disconnect the battery,, is the ecm located behind the glove box in this taurus gl. wagon
Jul 10, 2008 at 10:51 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,334 POSTS
Hello
The ECM is located in the passenger's compartment above the hvac box which you can get to by removing the glove box door. Here is some diagrams (Below) so you can see what I am talking about.
Cheers, Ken
Nov 11, 2017 at 7:21 PM
CHICO1969
Computer problem
1997 Ford Taurus 6 cyl Two Wheel Drive Automatic
where is the ecu located in a 1997 ford taurus
Nov 11, 2017 at 7:22 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
It passes through the firewall on the passenger side and is accessed from the engine side but most of it hangs inside under the dash.
TOJO PHILLIPS
  • 7 POSTS
Engine Mechanical problem
1995 Ford Taurus 6 cyl Two Wheel Drive Automatic 173000 miles
Where is the engine control module located?
Powertrain Control Module (PCM) On top right side of firewall.
TOJO PHILLIPS
  • 7 POSTS
is the powertrain control module and engine control module the same
Its the same thing-unless you are referring the ICM ( ignition control module ) as the computer-
TOJO PHILLIPS
  • 7 POSTS
i have installed new igintion module car still shuts off as if you turn the key off let it set for about 5 min it will restart what is my next step with out a scanner
STONEBOAT
Electrical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic 158000 miles
My 16 year old daughter just bought this Ford Taurus, The check engine light is on and the seller said that 'The control module' needs replaced. The seller even had the part from NAPA and said that her husband was going to fix it but didn't have the time. The unit is about 4" long and 1.5" wide has two places for electrical plugs. The side is steel and comes with a small tube of dielectric paste. I have looked all over and can't find where this goes. Someone suggested that it attaches to the side of the distributor but I can't see it. Any ideas?
OBXAUTOMEDIC
  • 3,711 POSTS
If it is a 3.0L engine it is mounted on the side of the distributor.
If it is the 3.8L engine it is located on the passenger side firewall.
Check the fuel pressure to rule out the fuel pump-could also be the ignition switch breaking up when it heats up-
TOJO PHILLIPS
  • 7 POSTS
how do you test an ignition switch?
PENCILCAR
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic 120000 miles
the dome light and the fan will not shut off. my husband believes it is the brain box. where is the brain box located? could this be the problem?
BMRFIXIT
  • 19,053 POSTS
Dome light most common to be door switch use penetrating oil and spray in the door latch open and close door few times try that on all doors
Fan always on!
is it the Coolant fan?
Check coolant sensor, coolant sensor connector and wiring
Check for codes
Check fan relay, check CCR module
