02 Sensor replacement
2004 FORD FOCUS
203,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
MOWMIKE
My check engine light came on the code was P2274, I was told it was an oxygen Sensor that needed replacing so I bought one at Auto Zone and know I need to replace it (02 Sensor 3) but I am not sure where it is located could you tell me or give me an image of it please.
Jun 23, 2015 at 9:04 AM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
Bank 1 Sensor 3 with be the furthest one back in the exhaust system. It will definitely be after the converter. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Here is how to replace both o2 sensors. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jun 23, 2015 at 9:42 AM
TTHUL
what would be causing oil to get on the o2 sensor we have changed 2 out of the 3 sensors. A mechanic can't figure out why there is oil on the sensor so he just cleaned it off and now if will be about another 100 miles and then the light will come on and show the code for an o2 sensor. What would be causing the oil to go there.
Dec 9, 2019 at 8:06 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
You can't clean an 0/2 sensor.
Are you seeing this oil on the outside of the sensor or on the part inside of the exhaust?
TTHUL
the mechanic took it out of the harness and he said that it was covered in oil.
WRENCHTECH
  • 20,761 POSTS
That doesn't answer my question. If the oil is on the outside, that just means you have an oil leak and it isn't effecting the sensor. I don't see a possible way to get the inside wet with oil. If it did happen to get oil on the sensor itself, it would be junk after that.
KENMUL
2004 Ford Focus
How do I find and replace the O2 Sensor? An Auto parts store used the diagnostic device which indicated the O2 sensor needed replacing. Just need to know how.
Thanks
BLACKOP555
  • 10,386 POSTS
well locate o2 sensor, remove harness and run the engine enough to heat up the o2 sensor and bung that way it comes out easier. use a o2 sensor removing socket, they are very easy to use and are less likely to round out the o2 sensor, but a 6 point wrench works just as well.
TIMGOINCRAZY
Engine Performance problem
2004 Ford Focus 4 cyl Two Wheel Drive Automatic
After being prompted by a code i replaces sensor one bank one on my focus. The car no longer dies and runs fairly smooth with a little sputtering. The check engine light came back on and is now throwing code P0054. This website does not include this code but my parts store says
Repair resource for sensor location identification and refers to a failure in the the powertrain control module.
I have no idea where to go from here. Any help would be greatly appreciated.
BLACKOP555
  • 10,386 POSTS
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
that sensor is for catalytic convertor efficiency. doesnt affect fuel air ratio but if you want to fix it i would suggest checking the connector and wiring on that sensor to make sure its not shorted or open. if thats all good up to pcm check sensor
TIMGOINCRAZY
Thanks for the advice and clarification.
Since I last posted my question I have changed the down stream O2 sensor and checked the wiring and all the plugs. Nothing seems damaged. All the shrouding is intact and none of the plugs are fouled or bent. The car is running just as bad as it was before i changed the upstream O2 sensor. I am at a loss. I am afraid the PCM i malfunctioning. Any more advice would be greatly appreciated.
BLACKOP555
  • 10,386 POSTS
are any new codes showing up on the vehicles computer or no. if so post back the exact codes. try to unhook the exhaust piping from manifold. run better now?
when does it run worst. cold, warm? al the time?
acceleration good. crusing good?
TIMGOINCRAZY
I have been driving the car since my last post. The car does not seem to sputter at any specific time. It will sputter during acceleration cruising, idle and sometimes not at all. I did run the A/C for a bit and it died repeatedly. It is still sending the same code P0045. I have not yet unhooked the manifold. Should i drive it around with that unhooked?
J.DENNEY36
CHECK ENGINE light was on and went Auto Zone had it checked on dianostic and got code p0133 (heated oxygen sensor bank 1) Question, I need to know where this is located, can you help? My car is a 2003 SVT Ford Focus 4 cyl.
BLACKOP555
  • 10,386 POSTS
yeah try it and see if its better. exhaust system could be plugged up causing vehicle to run poorly.
the vehicles having issues with o2's so check the cooling system. have it pressure tested to see if coolant is leaking into the cylinders causing bad running and issues with the o2 sensors.
WRENCHTECH
  • 20,761 POSTS
That sensor is right in the exhaust manifold at the front of the car. The heat shield will have to be removed to access it. https://www.2carpros.com/images/external/86101635.gif
RANDY SHARP
  • 165 POSTS
I have a 2003 Ford Focus zx3 2.3 Litre motor.I have been having a misfire code PO302 cylinder 2.It is a unusual problem because it cuts out when ac is turned on turn it off it is fine,but some times it will cut out without ac running.But I have a another DTC number,well we had Pep Boys scan it and it came up with P2274,,and I think it suppose to be P127,02 Sensor Signal Stuck Lean-Bank 1 Sensor 3.I understand the bank one front of motor,but where is Sensor 3 located.And does anybody out there know how to test them.Thanks
CARADIODOC
  • 34,309 POSTS
One thing to consider with the type of symptoms you described is a bad diode in the generator. That will reduce its maximum current output to exactly one third of its rated value which is not enough to run the entire electrical system under all conditions. A professional load-test will show that. With one bad diode of the six, "ripple" voltage will also be very high.
As for testing an oxygen sensor, the Engine Computer does that for you. You can watch its signal on a scanner, and you can introduce rich and lean conditions to see if it responds, but you have to remember they only measure unburned oxygen, not unburned fuel.
Normally when three oxygen sensors are used, number three is the one after the catalytic converter.
RANDY SHARP
  • 165 POSTS
So your saying the alternator could have a bad diode,but I just replaced the alternator about a year ago.And the 3rd 02 sensor is after the cat.Let me ask you a question my friend,you seem very knowledgeable,on mechanics.I want to purchase a 0BD 2 scanner,what kind would you recommend?And I surely appreciate all the help and advise you have given me.
CARADIODOC
  • 34,309 POSTS
A bad diode is just one of the possible causes of what you described but it's an easy one to quickly rule out or find with a professional load-test. That involves drawing the maximum possible current for a couple of seconds to see what can be delivered, not a simple voltage test. Measuring battery voltage while the engine is running will tell if the generator is working but not if it is capable of delivering the full current it was designed to.
As for scanners, I have the Chrysler DRB3 because with an extra plug-in card it will do emissions testing on all brands of cars sold in the U.S. on '96 and new models up to at least 2004, and a few models beyond that. With another card it will work on all Chrysler products back to '83 models.
I also have the Chrysler DRB2 made for all Chryslers from '83 through '95 but it requires various plug-in cartridges specific to the line of models you're working on.
If money is no object, Snapon has the MODIS and a few other models but they get you with expensive updates every year. My coworkers used a Genysis and liked it a lot but I never used them so I don't know much about them other than they're a popular, less-expensive alternative to the Snapon stuff.
You also have to look at the cars you're going to be using this on. '95 and older models had all different computer systems. For those, other than Chrysler products, I have a Monitor 4000. One cartridge lets me work on GM, Ford, and Chrysler, but aftermarket scanners never do all the functions of the manufacturer's scanners. Starting with '96 models the manufacturers started trying to standardize their computer systems, at least as far as the computer language they used. All of those models have the "OBD2" emissions system, (on-board diagnostics version 2). Besides being able to get really specific with well over 1000 potential fault codes, that is when they added the oxygen sensors after the catalytic converters to monitor how well they're working. To my knowledge everything through the 2003 models uses the OBD2 system. You need a scanner that conforms to that language if you want to use it on this car.
Starting with a few 2004 models they switched to the current "CAN BUSS" system. That stands for "controller area network". Every switch and sensor becomes a small computer module, right down to the headlight switch and door switches. The chances of developing electrical problems skyrockets but supposedly the many on-board computers do much of the diagnosis for you. I've only worked on a few trucks so far and it has always been an expensive computer that has solved the problems. I DO know I will never own another new car after seeing how ridiculously complicated they're designing them now.
New scanners are real expensive but they become obsolete real fast too. You might look on some online auction sites for used ones. Larger repair shops have multiple scanners so no mechanic has to wait to use one, but when they start to see fewer older cars they will often sell most of that equipment and just keep one on hand in case one of those cars comes in. Don't waste your money on a simple code reader. Many auto parts stores will read codes for you for free. Full scanners display all the data the various computers are seeing from the sensors in real time. They also access all or most of the computers on the vehicles, not just the Engine Computer. They're "bidirectional" which means along with receiving and displaying data, you can talk to the computers and command them to do things like fire injectors and ignition coils, and turn the radiator fan on and off. Those things are real useful when diagnosing problems.
One thing you'll get with the Snapon MODIS, and possibly others, is troubleshooting tips that aren't included in manufacturer's scanners. It has a section that gives you the description of fault codes and things to check. The list of stuff to check is pretty basic for an experienced mechanic but it can be real helpful for guys like me when we aren't familiar with the car we're working on. Some tests get right down to telling you which wire color to test and what to expect to find. I always taught my students to figure out those test points on their own so they could do it when they didn't have a book or scanner to tell them what to do, but for people with no electrical training those test steps can often lead you to the cause of a problem and save you a trip to the mechanic. If you plan on keeping your car a while, $3000.00 for a used scanner can save you more than that in diagnostic costs at the repair shop.
RANDY SHARP
  • 165 POSTS
Like I said before thank you so much for the information you have given me,I have been working on cars since I was 15 years old you know with dad,but I am not ase certified.Are you a teacher or something you are very knowledgeable about vehicles.Thank You for your time.
CARADIODOC
  • 34,309 POSTS
Was a tv / vcr repairman for over 40 years, mostly part-time. Was a mechanic during the same time, seven years at a Sears Auto Center, then ten years at a very nice family-owned Chrysler dealer. Then taught in a community college for nine years. My specialty areas are Electrical, Suspension and Alignment, Brakes, and Engine Repair.
RANDY SHARP
  • 165 POSTS
I have a zx3 ford focus 2.3l and I have a dtc 2274 02 sensor bank1 sensor 3 where is sensor 3 on this vehicle does anyone know for sure, I would appreciate it.
CJ MEDEVAC
  • 11,004 POSTS
this is the only diagram i could find in "prodemand"
it's gonna be the last one as the exhaust is leaving the engine
while i was in there i got you a frontal engine view also
the medic
TLEWIS123
Have had this problem for a year car runs but now when i drive it is fine but when i stop or idle for short period of time it basically sounds like its going to die. So went to get the code read problem is i already changed it once before and check engine light came on 1 day after so what could cause the O2 sensor to go bad would i also need to change the catalyic coneverter this nvr happened until i got bad gas at a gas station 1 yr ago.
AMRAAM35
  • 39 POSTS
This code indicates that the computer believes that your catalytic system is running inefficiently, i.e. you convert is getting old and clogged. This code can also be thrown by a faulty oxygen sensor. Because the car is running rough, i would estimate that one of your oxygen sensors are providing a false reading, causing the engine to correct for a fuel mixture that does not need to be corrected. this is likely causing you to run rich or lean, and it is most apparent at idle. My suggestion would be to replace your upstream oxygen sensor (closest to the engine) and clear the codes and see if that solves the problem. If not, replace the downstream one too. Oxygen sensors only last so long. Probably a good idea to replace both anyway.
Bill
DSHADOWALEX
Yes, I agree, replace both o2 sensors (at same time) before you go paying big money for a new catalytic converter. But if you have been running the car like this for a year now, the false reading from the O2 sensor(s) would create the lean/rich mixture and would eventually cause the cat to go bad. This is why it is always a good idea to keep your O2 sensors as fresh as possible.
