2001 Ford Focus Repair Question
Topics covered: Heater, Noise, Blower motor.
Asked on January 28, 2010
How do you replace the heater blower in a 2
Heater problem
2001 Ford Focus 4 cyl Front Wheel Drive Automatic 78000 miles
I have a 2001 Focus that has always has electrical problems. I've replaced the blower resistor twice, and finally the blower itself needs replaced, along with the resistor yet again.
Answer
Replied on January 28, 2010
2001 Ford Focus L4-2.0L SOHC VIN P
REMOVAL
1.Remove the lower passenger side footwell trim.
2.Detach the floor level ventilation hose.
3.Remove the blower motor.
*1.Disconnect the plug.
*2.Remove the three screws.
INSTALLATION
1.Remove the middle ventilation nozzle and open the glove compartment. NOTE:
*Procedure if there is a concern over whistling noises from the heating system.
*Set the air distribution switch to "Head area" and the temperature control switch to "MAX cooling"
2.Unclip the passenger side defrost nozzle air duct and lay it down over the open glove compartment cover. NOTE: Procedure if there is a concern over whistling noises from the heating system (continued).
3.Remove the two-part plastic joining tang on the heater housing.
*Cut the joining tang at the top end using side cutters, break it off at the bottom and discard it.
NOTE:
*Procedure if there is a concern over whistling noises from the heating system (continued).
*Do not allow any parts of the joining tang to pass behind the fascia crash padding.
4.Cut the sealing tape into a 50x50 mm square. NOTE: Procedure if there is a concern over whistling noises from the heating system (continued).
5.Feel for the gap in the heater housing, affix the sealing tape over the gap from the inside and press it firmly in place.
*The sealing tape must not be applied higher than the position shown in the illustration.
*1.Heater housing (shown in cross section)
*2.Sealing tape NOTE: Apply the sealing tape in the position shown.
WARNING: SHARP EDGES ON THE HEATER HOUSING.
6.Refit the components in reverse order.
