Ford F-250 Repair Question
Topics covered: Brake light switch, Neutral safety switch.
Asked on July 27, 2006
Shifting problem
I have an F250 and it won't shift from park unless you press the brake in hard. Any sugestions on what's causing the problem?
Answer
Replied on July 27, 2006
The mlps, known as the neutral safety switch, could be out of adjustment, or the electrical end if it could be acting up... possibly a good idea would be to replace the brake light switch, it's cheap, and relatively easy to do, see if it makes a difference
