2CarPros - Car Questions & Answers
Ford F-150 Repair Question
Topics covered: Fuse, Fuse box, Blown fuse.
Asked on February 24, 2007
Signal lights not working
1998 f150 4.2 203000 km
Directional lights not working.
I replaced the flasher relay and turn signal switch.
Fuses are good. Hazard and brake lights work. Is there a different bulb that may be burnt out or could it be something else.
Thanks.
Avatar Asked by spike
Answer
Replied on February 24, 2007
i would really have someone help you chack all of the bulbs first , then check the signal flasher and relay the hazard and turn signal should be the same try swapping them out , start simple dont replace parts unless you need to , if you need more help just post back here , i will get an email when you do
thanks
jim
Tiny Answered by CHEVYII
5 questions asked
Replied on February 25, 2007
There is another fuse box under the hood. This "power distribution box has a combination of fuses and relays. Check for a blown fuse there. The fuses here deliver power to the fuse box in the car. there are many fuses that control different inside fuses.
On my Explorer, it is fuse #3. Check your owners manual.
Tiny Answered by bhugg
5 questions asked
If you like , or dislike, our answers, let us know. vote for us if we help you with your problem. let us hear from you on if our solutions work.
Thanks
5 questions asked
