Mechanics
F150 CHARGING SYSTEM
1997 Ford F-150
Electrical problem
1997 Ford F150 6 cyl Two Wheel Drive Manual 137000 miles
New battery will not charge. New alt/reg did not solve problem. During testing, grounding the regulator proved 18 volts from alternator. New regulator and known good regulator all act the same.
At one point, grounding the regulator would make the system work properly until engine was shut down. This no longer happens.
Followed testing procedures laid out in Haynes manual and everything says replace regulator. Does not fix problem
JBNY
September 17, 2010.
Question have done all the things you have listed no charge?
I can hook up to other vehicle with jumpers and shows charge? Where should I look oh by the way new alt and bat
Tbrwolf
May 1, 2012.
Sorry ment this for Wrenchtech
AD
Tbrwolf
May 1, 2012.
AD
