blows hot air - air conditioning problems
1998 FORD EXPLORER
110,000 MILES • V8 • AWD • AUTOMATIC
EXPLODERFAMILY
with the hot-cold selector in any position in any position it will only blow hot air. With the selector in the max ac position it will blow semi cool air.
Jul 17, 2010 at 12:22 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
This sounds like a classic temperature blend door actuator that is not working due to a vacuum leak under the hood please take a look at this guide to see what I am talking about.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
This guide can help as well
Jul 17, 2010 at 12:28 AM
EXPLODERFAMILY
yes its cycling . Where is the blend door??
Jul 17, 2010 at 9:07 AM
  • 110,190 POSTS
If it is cycling, then the freon level is good enough to make the system to work. The blend air door is located in the HVAC system next to the heater core. That would be my first guess.
See the guide below, not vehicle specific, but it will show you what needs to be done
Jul 18, 2010 at 1:09 AM
TODDMANZ
Actuator fixed it.. Thank You !!!!
Jun 3, 2019 at 7:53 PM
THEBIEV
Just recently my air conditioner started blowing warm air and it took some time to blow a little cool air but not enough to cool off. Sounds silly but it blows cooler on the passenger side than the driver side. My husband checked belts,fuse.
Jun 3, 2019 at 7:55 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi thebiev,
Thank you for the donation.
Problem is due to a fault in the air blend doors and from symptom description, your system should be equipped with dual-zone meaning there are 2 separate electrical blend door motors an the driver side seems to be stuck in heater mode.
Check the air blend motor functions and linkages for sticking.
Sorry I could not find any diagrams to show you the location of the blend actuators. They should be at either of heater housing assy underdash.
RAYRAMOS
My 1996 Ford Explorer A/C is not working properly. I had the compressor changed last year. We do not use the Explorer very much because of gas prices. So everything was serviced in accordance with. However, now when I turn the Air conditioner on, it blows cold air for a little while, then you hear a door or something close and it starts blowing extremely hot air. Does anyone know what this door or panel may be? And what is causing it to close? Where is this Door/Panel located?
Any help will be appreciated. Thanks in advance.
PAT2257
I had this problem on my 96 Explorer. On the Explorer, hot water is always running through the heater core. There is a door inside the duct that blends the hot air that passes over the heater core and the cold air that passes through the A/C coil. The door is acuated with a small electric motor that is mounted to the top of the duct under the dash. On mine, the motor turned the door too far, and the door eventually cracked. It would have cost $800 for the dealer to replace the whole duct unit. Instead, I cut a slot in the bottom of the duct and pulled out the door, glued together the broken parts, reinstalled the door, and reinstalled the bottom section of duct. Then, I put JB weld on the heater knob so it wouldn't turn as far to prevent it from happening again. When I cut the slot in the bottom of the duct, I only cut three sides, so that one side was still attached to the duct, and I just bent down the part I cut to get the door out.
JOE39168
Where is the port to recharge unit or is there ant else i can do?
TECHS IN
  • 14 POSTS
You could also check the ac pressure switch if the compressor is not kicking in this could indicate that the pressure switch is faulty. Also the low pressure side port is on the larger line going to the accumulator
ROD2639
I have a 1998 Ford Explorer 4x4 (6 cyl) and when I turned on the heat it only blew cold air. I made sure that the knob was on the hot side and waited a ten minutes to warm the truck up, but still no heat, only cold air, but not the cold air that would be coming from the a/c. What can it be?
Aug 12, 2019 at 5:51 PM (Merged)
RACEFAN966
  • 5,029 POSTS
If the radiator is completly full then it probably a blend door or blend door motor problem. So what is happening is that the blend door is not closing the cold air off so you get outside are without going through the heater core. Here is the blend door so you know what you are looking for
https://images.2carpros.com/forum/automotive_pictures/249564_379286_1.jpg
Hope this helps let me know how it goes.
MICHELLE_84
My a.c just blows hot air I took it to a mechanic and the compressor would not turn on but when he connected the compressor direct it clicked on but was still just blowing hot air it has no leaks it was recharged also the pressure is right where it is supposed to be. I opened the the glove box and the blend door does not open or close I did it manually still no cold air the acuator I took it out and it looks fine I dont see any wear or cracks on the teeth of the the wheels in there. Please need help any idea what it can be I have a 1997 ford explorer eddie Bauer v6 sohv 4 L.
  • 110,190 POSTS
Are you sure the system held its charge? As far as the compressor, did the mechanic check the cycle switch? Also, was the system pressure checked to make sure there are no blockages in it?
MICHELLE_84
Yes it held its charge I dont think he checked the cycle switch and yes he checked the pressure he said it was where it was supposed to be
  • 110,190 POSTS
I would have him check to make sure the cycle switch is working. That is what energizes the compressor clutch.
TODD37
Hi, I need help getting pointed in the right direction about an a/c problem.
Here's the info: Ford Explorer XLT 1999, 145,000 miles, 4.0 SOHC.
Porblem: a/c stoped working last week
I thought it might be something simple like a recharge so I went ot recharge it. Put on the gauge at the reciever/drier. This was the only place I could find to attach the gauge anywhere in the line. I turned the a/c to max with the fan on high. I noticed the reading would shoot from normal (on the higher side) to low. What I also notced was that this was happening when the clutch on the compressor was engaging. What looked to me was that the clutch wasn't staying engaged for more than a few seconds at a time, it would click on and click off. So now I don't know if it's a problem with the compressor, the clutch plate on the front of the compressor, something electrical, or something else. I don't have the money to take it somewhere or get taken by a not so honest mechanic. Please Help! :(
98RANGERXLT
  • 301 POSTS
You are on the right track close the high side put ac on NORM fan on high temp full cold fill until comp stays on
TODD37
Hi Fordman16,
If this works that would be awesome let me just walk thru this with you if you don't mind I still have a question or two.
The first is... am I ok with recharging it at the reciever/drier? it was the only place I could see to try to recharge it at.
I'm not sure what exactly you mean when you say...close the high side?
the next steps are:
Set fan to normal or lowest setting.
Set the temp control to High (hot...red area) not cold (blue area)
So by doing this there should not be the back and forth spike on the gage from the refrigerant can from the on/off of the clutch plate engaging on the compressor? I'll tell you when that gage would spike to the high/warning side I was getting a little nervous.
One other little question... something goes totally wrong... worst case the car will still runs normal just no air because I blew the a/c system to hell...?
Thanks again!!!
RMOORE09
  • 132 POSTS
Hello, My Ford Explorer has an unusual problem. It will drive fine, however when you turn the AC on it will drive fine for a little while then when you take off from stop, it will rev up and kinda stall between 1st and 2nd gears. Eventually after a while doing that, it will act like the rear end is slipping when taking off. When you turn the ac off it will continue with these symptoms then after a little while it will drive fine. I have replaced the battery and these symptoms do not recur as much now but it still does it every now and then. Diagnostic codes say Bank 1 too lean and sometimes Bank 2 too lean. Also I hear a vacuum leak coming from the back of the engine and it sounds like its between the firewall and the dash. When you turn off the ac off or on when the vehicle is off you can hear a air sound. I hope I get a reply, this problem has been annoying.
My vehicle has 203560 miles and it is a 4.0L V6 OHV.
Thank you!
  • 110,190 POSTS
A vacuum leak will give you a lean mixture, so that is most likely why you are getting the codes. Additionally, it will cause the engine to run poorly. Find the leak. Chances are it is going to the HVAC system. Repair it and I bet the problem goes away.
Let me know what you find.
RMOORE09
  • 132 POSTS
Thank you for the reply. Where could I find the leak. The leak comes from the back of the engine but I cannot find it. Could it be between the firewall and dash?
MYADDY504
I have a 93 ford explorer.. rebuilt 6 cylinder engine with 80k... rebuilt r-134 a/c system( condenser, accumulator and compressor) The system is not blowing cold as it should.. I check the accumulator, i believe that is the piece that has the orifice in it, and it seems to be working fine..creating lots of condensation and is very cold to the touch.. however the air still only blows cool... not as cold as it should. Where and how should I check for the problem.. thank you.
MYADDY504
I rebuilt the a/c and bought all new parts to convert the r-12 into r-134.. Yeah I am not real sure on what the parts are called. It is manual temp control. I don't have anything but wrenches lol.
MYADDY504
I don't believe I need to charge it.. I took it to the shop and they hooked up to their guages and said that it had the proper pressure... and like I said everything is cold until it reaches the cab of the truck....what would I use the home kit for??
MYADDY504
No I believe we just cleaned the evaporater core... And we did add the right amount of oil.. I am getting answers from Autozone that it sounds like my blenddoor on the truck isn't functioning right beacuase an actuator is bad and isn't pulling the right amount of vacuum.
RANDY T
1997 Ford Explorer Eddie B. 4.0L 127K mi. For the past two summers the A/C has been blowing progressively warmer air. This year (2 weeks ago) I brought it to the shop to have the system recharged (134a). It was low on freon. The tech said I could have a slow leak and also added the dye. No problem. They returned the vehicle, and as I was driving the transporter back to the shop the A/C began to blow warmer and warmer air. (The transporter said he noticed the problem driving from the shop.) At idle the A/C blows cool air, however as RPM increases so does the temperature of the air... even if the vehicle is parked. The shop checked the system when we got there and all pressures were correct at both low RPM and high RPM. The tech said the compressor and everything else outside the vehicle was functioning properly. He said the problem could be with the blend door. The recycled air, vent/floor and blend door are actuated with vaccuum. As RPM is increased the position of the blend door actuator does not change (none of the actuators change position). The tech can not find the problem... "everything seems to be working fine". This happens when the A/C is in the MAX AC setting or the AUTO setting. The heater works good... floor vent works good... fresh recycled works good... and the AC works good when at idle but as RPM increases (even parked) the air out gets warmer. Any suggestions would be appreciated.
RAYRAMOS
I just happen to have the same problem with my 1996 LTD Explorer 5.0L. The problem I had was the A/C would come on work fine then cut itself off and blow hot air. The technician told me it was the Blend Door. I had it changed to the tune of $1,000 dollars. Haven't had a problem since. This was two years ago. The have to take the dash apart to get to it. $300 for door, and $700 for labor.
SUNNIDAZE
Will having your engine coolant flushed cause your a/c to stop blowing cold air?
Aug 12, 2019 at 5:52 PM (Merged)
  • 31,937 POSTS
Hi there,
No this will not directly affect the A/C, i would just have the power wire to the compressor checked, it may have been disconnected by accident, if that is OK have the pressures tested and check the charge of refrigerant is not low, start here.
Mark (mhpautos)
