Cabin Air Filter?
RMG1999
  • 2005 FORD EXPLORER
  • 6 CYL
  • AWD
  • 27,000 MILES
How do I change the cabin air filter in my car? I cannot locate it?
Saturday, February 27th, 2010 AT 12:05 AM
  • 108,328 POSTS
This car does not have a cabin air filter. Use 2CarPros anytime, we are here to help. Please tell a friend.
Monday, March 1st, 2010 AT 8:00 AM
RMG1999
  • 6 CYL
  • 4WD
  • 27,000 MILES
Where is the air cabin filter on a 2005 ford explorer located?
Saturday, January 19th, 2019 AT 12:01 PM (Merged)
  • 108,328 POSTS
I don't believe you have one. If you do it will be under the hood near the cowl on the passanger side, or behind the glove box. I don't believe you have one.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 FORD EXPLORER
  • 137 MILES
Where is my air condition in cabin filter located. I did not see it behind the glove compartment. 2003 ford explorer XLT
Saturday, January 19th, 2019 AT 12:02 PM (Merged)
HMAC300
  • 48,601 POSTS
You may not have one, auto parts stores list them but they are an aftermarket thing if youwant to install one.
U001GLM
  • FORD EXPLORER
I have a Cigarette Smoke problem in the used 2003 Explorer XLT I just purchased. Any suggestions how to eradicate? Is there a Cabin Filter in this model, and if so, where is it? Thanks!
GARFIELD
  • 197 POSTS
You can try changing the cabin air filter, an old trick that I have done in the past is put cups of white vinegar in the floorboards and close the car up. The white vinegar smell kills the smell of the smoke while the smoke smell kills the vinegar smell. I friend showed me this trick in his house where the smoked 5 packs a day and you couldn't smell smoke at all. Good luck and hope it help, Merry Christmas
Gary
SERVICE WRITER
  • 9,123 POSTS
Sometimes these filters are listed, but not always used on all models. It drives me crazy to spend 15 minutes geeting to them to find out there isn't one there. :Evil:
Generally they are behind the glove compartment or accessible through the wiper cowl area. I would call the dealer and ask them.
RTRIJO
  • 2001 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 162,000 MILES
2001 ford explorer xlt location of air cabin filter
Wednesday, December 4th, 2019 AT 1:42 PM (Merged)
It doesn't have one
NOTE: The air distribution system of this vehicle cannot be equipped with a cabin air filter.
BIGNASTYTAZ
  • 1999 FORD EXPLORER
  • 6 CYL
  • FWD
  • 172,659 MILES
Where is the cabin air filter I need to change it
Wednesday, December 4th, 2019 AT 1:43 PM (Merged)
BILLYMAC
  • 2,204 POSTS
If you have one it is on the passengers side in the firewall under the hood you will see a removable panel that say;s cabin air filter
JADEDEGO
I was just wanting a general idea of how to change the air cabin filter. Any help would be appreciated.
Monday, January 4th, 2021 AT 8:34 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
I am not positive but I don't think the Explorer has a cabin air filter. If it does you may need to call you local Ford Dealer. I cannot find any info on it.
MAURICEV69
  • 1997 FORD EXPLORER
  • 4 CYL
  • 64,944 MILES
How do you replace the cabin air filter in the liftgate interior panel?
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle didn't come with a factory-installed cabin air filter.. if there is a cabin air filter on yours then it was added on as a dealer installed option... Should be behind the glove box
See the guide below on cabin filter replacement
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
HEATONME
  • FORD EXPLORER
Does my 2002 Explorer XLT have a cabin air filter? The air pressure form the vents, when on highest fan speed, does not blow as hard as it used to.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
Your car does not have a cabin air filter. Is the blower motor turning slow?
Here are a couple guides that will help you
https://www.2carpros.com/articles/blower-motor-testing
It could be an actuator problem as well
Please let us know how ti goes
Best, Ken
WORKNDAILY
I had the same problem so I looked up a lot of different things in a lot of different ways and watched several different videos of how people problem solve this issue the most common issue would be the fresh air vent door breaking from the actuator switch and the door falling over top of the vent as well as a lot of debris getting sucked in and settling on top of the screen that covers the blower so between the two of those it completely breaks down all of the suction capability of intake are the which then restricts the airflow to any of your vents the problem is it's an accessible so you have to make it accessible and this link that I'm going to post is how you do that.
https://youtu.be/sG1R40SVN6w
KEN L
  • 43,110 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
