2CarPros - Car Questions & Answers
1998 Ford Explorer Repair Question
Topics covered: Brakes, Engine, Brake caliper.
Asked on March 6, 2008
1998 Ford Explorer Brake paddel sinks to the floor when eng
I had a damaged front caliper driver side and all the brake fluid leaked. I just finished replacing front rotors, calipers, and brake pads for both sides. After installing the new parts, I bled the brakes both sides. If you pump brake paddel once or twice when engine is turned off, the paddel gets hard as it would be under normal circusmatance. But, when engine is running and you press the brake paddel, it sinks to the floor without any pressure. The vehicle doesn't stop and brakes don't work. I have bled the brakes twice and there is not air in the system (as I know). What am I doing wrong? i have changed master cylinder and brake calipers on other vehicles (Nissan Maxima 1987, Pontiac Sunbird 1983) before without any problems. Can you please help me? Thanks.
Avatar Asked by lanstec
Answer
Replied on March 8, 2008
:D
Well I didn't get any help but I solved the problems. Wanted to post back to forums so it might help someone like me. The problem was that I had already mounted the new calipers on the Explorer before "bench bleeding" them. Even though after install I had let the gravity run fluid thru calipers and then bled the system as you would normally do, there was air traped on the top corner of the calipers because the bleed nipple is on the bottom side of the calipers.
Solution. I uninstalled the calipers. Turnered them upside down with the bleed nipple being the highest point on the calipers and let the gravity do its work. A lot of traped air came out. Once clear fluid was filled in the plastic tubing, I tightened the nipple. Instaleed the calipers and then bled the system again. Worked perfect.
Tiny Response from lanstec
1 question asked
