[quote:3acbd1f395="JIM0116"]Engine Mechanical problem
1995 Ford Explorer 6 cyl Four Wheel Drive Automatic 160,00 miles
My 1995 Ford Explorer will not start. I have replaced the Fuel Pump and the fuel filter, at first the pump would not work because the fuel pump relay was not ground. I fix the that problem but now it still will not start. Someone told me that it may be the computer and someone also said it may be the EEC Relay but I dont know where that is. I need help it has been down for 2 weeks.[/quote:3acbd1f395]
Ok, I s your check engine light on?
Does it turn over and just not start or it doesn't do anything or it clicks.
If it turns over and doesn't start - do you have spark at the plugs? If so what Color is the spark.
If you are sure it is getting fuel and has good spark and it clicks when trying to start, find the starter relay, follow the positive cable it is within 1 foot of battery. Turn key to run position then take a peice of wire and jump the 2 large terminals. If starts replace the relay.
Post findings here in forum....
Dec 30, 2020 at 6:42 PM
(Merged)
