1998 Dodge Stratus
Heater problem
1998 Dodge Stratus 6 cyl Two Wheel Drive Automatic 134000 miles
As I was driving to work today. The heater was on, I turned it off as it was getting warm in the car. I turned it back on a little later and it wouldn't work on any speed except high. I checked the fuse in the inside fuse panel and thought of checking the a/c relay under the hood but if it was burnt out would I still get heat on high speed? I'm not sure what to check now, can you help? Please!
Thanks very much for any info you can provide.
February 19, 2008.
There is a blower motor resistor on the right side of car behind dash on HVAC plenum. Follow the wires from the blower motor back to the resistor. See if it gets power to it at all settings, get back with what you find
Feb 19, 2008.
