Fuel filter location
2001 DODGE STRATUS
96,000 MILES • 4 CYL • FWD • AUTOMATIC
AW27932
  • 6 POSTS
Hey guys,i have a 01 Stratus SE 2.4l DOHC and i wanted to know if the fuel filter is IN the tank or is it just by the tank and around how much does a filter cost? Thanks for your help
Sep 16, 2010 at 4:54 AM
  • CAR REPAIR CONTRIBUTOR
The fuel filter is part of the fuel pump module. To remove the module you must first remove the tank, here's a guide and diagrams for this procedure
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Sep 16, 2010 at 5:01 AM
AW27932
  • 6 POSTS
Hey rasmataz, i was told by a guy at AdvanceAuto today that they dont sell the fuel filter and that i would have to buy the fuel pump module and that is $214. I guess that new filters are in the fuel pump modules, is that right? Is there any other way of getting this done? If not i will have to get the module and about how long does it take to install the module?
Sep 16, 2010 at 2:56 PM
Double check if its replaceable w/o the module, we talking about big time money on the module-see below
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_filter_5.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_filter1_1.jpg
Sep 16, 2010 at 5:36 PM
AW27932
  • 6 POSTS
From my understanding and from what the guy told me, he pulled it up and it had unserviceable and that i had to buy the module.Also he was telling me that alot of cars are going to that now.
Sep 17, 2010 at 8:59 AM
AW27932
  • 6 POSTS
Ok i just did some calling around. I was told by a guy at another AdvanceAuto that the pump just has a strainer and that again i would have to drop that tank and put it in.I called Napa and he looked it up and told me that it is just outside the tank and has quick disconnect hoses i believe he said.
Sep 17, 2010 at 9:18 AM
AW27932
  • 6 POSTS
[quote:e60ab2457b="aw27932"]Ok i just did some calling around. I was told by a guy at another AdvanceAuto that the pump just has a strainer and that again i would have to drop that tank and put it in.I called Napa and he looked it up and told me that the fuel filter is just outside the tank and has quick disconnect hoses i believe he said.[/quote:e60ab2457b]
Ok just returned from Shell station shop.The worker lifted my car we searched and searched and could not find any type of filter outside of the tank.So does that mean the filter is INSIDE the tank and how would i go about getting a filter unless its the one that the guy at Napa showed me but it has some quick disconnect hoses and some type of mounting bracket. Is the strainer the guy from Advance told me considered the fuel filter? I dont know....
Sep 17, 2010 at 12:17 PM
MULDOON
  • 79 POSTS
I replaced mine on my 1996 Stratus 4 cyl 2.4 l , it was on top of the fuel tank I had to lower the tank, not all the way and then replace, check edmunds book first, make sure tank has little gas, good luck, Declan.
Sep 21, 2010 at 3:28 AM
AW27932
  • 6 POSTS
[quote:cc966daedb="muldoon"]I replaced mine on my 1996 Stratus 4 cyl 2.4 l , it was on top of the fuel tank I had to lower the tank, not all the way and then replace, check edmunds book first, make sure tank has little gas, good luck, Declan.[/quote:cc966daedb]
Hey did it have quick disconnect hoses on yours? I'm thinking mine is different being that i have an 01.I'm going to try and get someone to lower my tank and see if it is there or actually in my tank and if so i will have to get the feul pump module.
Sep 21, 2010 at 12:53 PM
MULDOON
  • 79 POSTS
I believe it had but am not sure, anyway why do you need to change the filter, also get that edmunds book, I like the guys at advance but that book does not lie, sometimes I call a Chrysler dealer and ask to speak to a mechanic, tell them you are a mechanic also but are wondering if there is a short cut, good luck Declan.
Sep 21, 2010 at 7:14 PM
JG_8MAN
I am wondering where the fuel filter is located on this car and how much mechanical skill is required to replace it. I am in Europe and would like to change it out myself but I don't have access to a garage so any help would be greatly appreciated. Thanks
Jason
Aug 6, 2018 at 12:56 PM (Merged)
ZACKMAN
  • 4,202 POSTS
You have a fuel strainer at the end of the fuel pump assembly. Replacing the strainer requires dropping the fuel tank down, removing the fuel pump assembly, prior to getting to the strainer filter. It is not advisable to perform the work without a garage, in my opinion.
GRNEYEDKAT
Where is the fuel filter located on the 98 Dodge Stratus ES
MIKEYBDMAN
  • 623 POSTS
The fuel filter mounts to the frame above the rear of the fuel tank. Here is a guide to show you what yoo are in for when doing the job.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Here are diagrams (below) showing the fuel filter location on your car
Cheers
SCHUYLER WRAGGE
I have a 98 dodge stratus and need to know where the fuel filter is and if it is something my dad could fix?
CARADIODOC
  • 34,309 POSTS
I can add that except for diesel engines, unless the fuel filter is rusted and leaking, you will never solve a running problem on a Chrysler product by replacing the fuel filter. They commonly last the life of the vehicle.
BRINLY
2000 Dodge Stratus 6 cyl Two Wheel Drive Automatic
Where is the fuel filter located on a 2000 Dodge Stratus?
Fuel Filter
https://images.2carpros.com/forum/automotive_pictures/12900_ff_24.jpg
Fuel Pump Module/Fuel Filter
https://images.2carpros.com/forum/automotive_pictures/12900_ff1_6.gif
FRANK TAYLOR
where is the fuel filter located
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter is located on the frame, above rear of fuel tank. Fuel tank must be lowered for access to fuel filter. Fuel lines are permanently attached to fuel filter.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_55.jpg
Need removal and installation instructions? Just ask and you shall receive. Thanks for using 2carpros.com!
MSEGOVIA
Where is the fuel filter on this vehicle?
BIG C
  • 5 POSTS
I have a 2003 Stratus and mine is located in the fuel tank.
LINNYLOUV
1998 Dodge Stratus 4 cyl Front Wheel Drive Automatic
JNOVACK
  • 723 POSTS
it is located Under vehicle, passenger side, below seating area, front of fuel tank, mounted on frame in fuel line
LIL_ROOS_MAMA
where is the fuel filter located?
BILLYMAC
  • 2,204 POSTS
Hi the fuel filter is under the car find the lines comeing out of the gas tank filter will be near them. good luck billymac
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, passenger side, below seating area, rear of fuel tank, mounted on chassis in fuel line
Aug 6, 2018 at 12:57 PM (Merged)
KSCOTT91109
1999 Dodge Stratus 4 cyl Four Wheel Drive Automatic
i just need 2 no where is the fuel filter on a 1999 dogde stratus
JDL
  • 16,098 POSTS
Welcome, my info says it is located under the vehicle, passenger side, front of fuel tank, on frame rail.
WHISTLEDGM
Can you tell me where the fuel filter reset switch is located? My daughter ran her car low in gas. The engine will turn over but won't start. The fuel pump is engaging when you turn the swtich on.
SERVICE WRITER
  • 9,123 POSTS
There is no reset on this one.
Try spraying some carb cleaner or starting fluid into the throttle body and see if it runs for a minute or not.
DAWANDER
hOW DO YOU CHANGE A FUEL FILTER IN THIS CAR?
Aug 6, 2018 at 12:58 PM (Merged)
TWINKEY1
  • 49 POSTS
1 is in the tank. The other is right next to the tank, under the mounting strap bolt.
JAYDESMOMMY
how much do u think it would cost me to take my 99 dodge stratus in to get the fuel filter changed?? i am a female so i have no clue.lol
WRENCHTECH
  • 20,761 POSTS
The frame mounted filter calls for 1 hr labor so calculate that by the shop.s labor rate.
