1997 Dodge Stratus Repair Question
Asked on July 22, 2010
1997 Dodge Stratus won't idle
Engine Mechanical problem
1997 Dodge Stratus 4 cyl Two Wheel Drive Automatic 120,00 miles
I have a 97 dodge stratus, 2.4, auto, have replaced the MAF sensor, both oxygen sensors, idle,air flow sensor, fuel filter, before replacing these; it ran as if the auto choke was stuck, now it seems to starve for fuel, only at idle, or when letting off the accelerator? Don't know what else to replace? Where is the fuel regulator? Could this be it? or the injectors?
Answer
Replied on July 22, 2010
Check the EGR valve and throttle position sensor to include a fuel pressure check
