truck starter
1999 DODGE RAM
240,000 MILES • V8 • 2WD • AUTOMATIC
AHALL4916
where is the starter on my 1999 dodge ram 1500?!
Aug 6, 2011 at 9:51 PM
  • CAR REPAIR CONTRIBUTOR
If you follow the battery positive cable towards the engine it will take you straight to it. This guide will help you walk through the repair
Aug 6, 2011 at 9:53 PM
ROBBO51269
how do i change the starter on my 1999 dodge ram 1500
May 3, 2019 at 2:15 PM (Merged)
MERLIN2021
  • 17,250 POSTS
1. Disconnect battery negative remote cable from remote ground post. 2. Raise vehicle. 3. Remove 3 bolts attaching starter to engine. 4. Remove battery positive feed wire from starter. 5. Remove starter solenoid assembly from transmission housing. Position the starter to gain access to the posi-lock wiring connector. 6. Position jack stand beneath engine and slightly lift to relieve pressure from left engine mount. 7. Remove 3 left engine mount mounting bolts from engine block. 8. Jack engine up slightly to give more room to maneuver starter assembly. 9. Slide rear of starter motor out between catalyst and engine mount. 10. Disconnect posi-lock starter solenoid connector. 11. Remove the starter from vehicle. 12. To install, reverse the removal procedures. Clean corrosion/dirt from the cable and wire terminals before installing wiring to the solenoid. Reconnect posi-lock connector right after starter is placed into position.
DON SAMSONITE
That is one of worst right ups I've ever seen. You don't have to lessen any motor mounts. ANF the starter on a 99 dodge ram only has 2 bolts, not 3.
Jul 28, 2025 at 2:40 PM
